继承问题
为啥页面转传移后继承不了呢……
URL也沒有op=view
http://localhost:8075/webroot/decision/view/report?viewlet=%2FCI_important_auto.cpt&__parameters__=%7B%22__pi__%22%3Atrue%2C%22op%22%3A%22view%22%2C%22p_year%22%3A%222019%22%2C%22p_month%22%3A%224%22%2C%22p_index_pattern%22%3A101%2C%22p_honbu%22%3A%22BT%22%2C%22p_buten%22%3A%22%E6%9C%AC%E5%BA%97%E8%87%AA%E5%8B%95%E8%BB%8A%E5%96%B6%E6%A5%AD%E7%AC%AC%E4%B8%80%E9%83%A8%22%2C%22p_store_type%22%3A%22%22%2C%22p_channel1%22%3A%22%22%2C%22p_channel2%22%3A%22%22%2C%22p_dairiten_org%22%3A%22%22%2C%22p_previous_year%22%3Afalse%2C%22p_previous_year_12%22%3Afalse%2C%22p_detail%22%3Afalse%2C%22p_get_org%22%3A%222%22%2C%22p_index_select%22%3A%220%22%2C%22p_selects%22%3A%22%22%2C%22p_select_patterns%22%3A%22%22%2C%22p1%22%3A%22%22%2C%22p_role%22%3A%22%E5%88%A9%E7%94%A8%E8%80%85%22%2C%22p_ex%22%3A%222020%22%2C%22p_number%22%3Afalse%2C%22p_CI%22%3Afalse%2C%22p_sql_text%22%3A%22%22%2C%22p_attr11%22%3A%22%22%2C%22p_conj11%22%3A%22%22%2C%22p_attr12%22%3A%22%22%2C%22p_conj12%22%3A%22%22%2C%22p_attr13%22%3A%22%22%2C%22p_attr21%22%3A%22%22%2C%22p_conj21%22%3A%22%22%2C%22p_attr22%22%3A%22%22%2C%22p_conj22%22%3A%22%22%2C%22p_attr23%22%3A%22%22%2C%22p_attr31%22%3A%22%22%2C%22p_conj31%22%3A%22%22%2C%22p_attr32%22%3A%22%22%2C%22p_conj32%22%3A%22%22%2C%22p_attr33%22%3A%22%22%2C%22p_num_attri1%22%3A%22%22%2C%22p_num_val11%22%3A%22%22%2C%22p_sign11%22%3A%22%22%2C%22p_num_val12%22%3A%22%22%2C%22p_sign12%22%3A%22%22%2C%22p_num_attri2%22%3A%22%22%2C%22p_num_val21%22%3A%22%22%2C%22p_sig
FineReport 室岡家源 发布于 2020-9-10 09:20 (编辑于 2020-9-10 09:20)
yiyemeiyingLv4高级互助
发布于2020-9-10 09:43
仔细观察代码,url中的特殊符号(=)被浏览器编译了而已,正常继承!
  • 293浏览人数
  • 最后回答于:2020-9-10 09:43
