Tomcat服务器后台一直在报严重NULL,但是访问报表一切都正常
十一月 15, 2018 4:13:48 下午
严重: null
java.lang.NullPointerException
	at com.fr.plugin.chart.attr.CompareSeriesJSONHelper.getSeriesHashMap(Unknown Source)
	at com.fr.plugin.chart.attr.CompareSeriesJSONHelper.compareDataJson(Unknown Source)
	at com.fr.plugin.chart.glyph.VanChartPlotGlyph.addRefreshSeriesJSON(Unknown Source)
	at com.fr.plugin.chart.glyph.VanChartPlotGlyph.addAutoRefreshData(Unknown Source)
	at com.fr.plugin.chart.vanchart.VanChartGlyph.addPlotRelativeJSON(Unknown Source)
	at com.fr.plugin.chart.vanchart.VanChartGlyph.toJSONObject(Unknown Source)
	at com.fr.chart.chartglyph.ChartGlyph.toJSONMap(Unknown Source)
	at com.fr.web.core.A.D.A(Unknown Source)
	at com.fr.web.core.A.D.B(Unknown Source)
	at com.fr.web.core.A.F.actionCMD(Unknown Source)
	at com.fr.web.core.WebActionsDispatcher.dealForActionCMD(Unknown Source)
	at com.fr.web.core.WebActionsDispatcher.dealForActionDefaultCmd(Unknown Source)
	at com.fr.web.core.A.aC.process(Unknown Source)
	at com.fr.web.core.ReportDispatcher.dealWithOp(Unknown Source)
	at com.fr.web.core.ReportDispatcher.dealWeblet(Unknown Source)
	at com.fr.web.core.ReportDispatcher.dealWithRequest(Unknown Source)
	at com.fr.web.BaseServlet.doGet(Unknown Source)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:635)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:742)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:478)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81)
	at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:650)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342)
	at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:803)
	at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
	at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:868)
	at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1459)
	at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.lang.Thread.run(Unknown Source)
FineReport zhouxi 发布于 2018-11-15 16:44
zhouxiLv5见习互助
发布于2021-6-16 10:15
原来是图表设置了定时每6秒更新,取消了就好了
离_度Lv3中级互助
发布于2018-11-16 17:39
空指针错误-http://help.finereport.com/doc-view-386.html看一下这个文档对你有没有帮助
toorLv2见习互助
发布于2018-11-15 16:51
看提示是图表的插件报的,没找到数据源吧.
  • zhouxi zhouxi(提问者) 后台每个6秒钟就报这样错误,访问报表一切正常呀,搞不懂什么情况
    2018-11-15 17:10
  • zhouxi zhouxi(提问者) 我找到了有问题的那张模板,但是无论是本地预览还是服务端预览,都没有问题,就是服务器后台一直报错
    2018-11-15 17:26
  • toor toor 回复 zhouxi(提问者) 有没有可能是调用了某个没有数据源的数据,然后这个字段没在报表中展示?
    2018-11-15 17:29
  • 707浏览人数
  • 最后回答于:2021-6-16 10:15
