sql函数
sql("SampleDashboard","select count(distinct office_name,model_name,category_name) totalCount from ProStateDetail
where ${if(len(ts_xh)=0,'1=1','model_name like "%'+ts_xh+'%" ')} and category_name in ('"+ts_pl+"') and category_model_state='"+is_ts+"' ",1,1)
这里面的if该怎么使用?
FineReport pengfuqiang96 发布于 2020-12-11 13:38
朝赟丶Lv6初级互助
发布于2020-12-11 13:41
=sql("FRDemo","SELECT * FROM STSCORE where 1=1 "+if(len(p1)== 0,"","and CLASSNO = '"+p1+"'"),3,4)
参考这个文档
https://help.fanruan.com/finereport/doc-view-846.html?source=1
  • pengfuqiang96 pengfuqiang96(提问者) var sql = \"select count(distinct office_name,model_name,category_name) totalCount from ProStateDetail where category_name in (\'\"+ts_pl+\"\')and category_model_state=\'\"+is_ts+\"\' \" + if(len(ts_xh)=0,\"and 1=1\",\"and model_name like \'%\"+ts_xh+\"%\' \"); var s = \'sql(\"SampleDashboard\",\"\' + sql + \'\",1,1)\'; var totalCount = FR.remoteEvaluate(s); 还是跑不出来
    2020-12-11 14:05
发布于2020-12-11 13:43
where "+if(len(ts_xh)=0,"1=1","model_name like '%"+xh+"% '")+
"and category_name in ('"+ts_pl+"') and category_model_state='"+is_ts+"' ",1,1)
AmyQLv6初级互助
发布于2020-12-11 13:43
sql("SampleDashboard","select count(distinct office_name,model_name,category_name) totalCount from ProStateDetail where 1=1 ${if(len(ts_xh)=0,'','model_name like "%'+ts_xh+'%" ')} and category_name in ('"+ts_pl+"') and category_model_state='"+is_ts+"' ",1,1)
  • 435浏览人数
  • 最后回答于:2020-12-11 13:43
