报表刷取慢,如何优化sql
/*筛选设备*/
WITH MN1 AS
(SELECT MACHINENAME FROM
  (SELECT MACHINENAME FROM RPTMGR.MACHINE_SEQ WHERE MACHINENAME IN ('${ddcUnit}'))
  ${IF(ddrAlarmYN= "N","WHERE 1=1","WHERE 1=2")}
  AND SUBSTR(MACHINENAME,9,4) NOT IN('UD01','UNLD','OPK1')
,MN2 AS
  AND SUBSTR(MACHINENAME,9,4) IN('UD01','UNLD','OPK1')
/*计算基础时间差*/
,PTH AS
(SELECT RN,TIMEKEY,PRODUCTNAME,PRODUCTPROCESSEDMACHINENAME,(CASE WHEN SUBSTR(PRODUCTPROCESSEDMACHINENAME,9,4) IN('UNLD','UD01','OPK1') THEN PRODUCTINTIME ELSE PRODUCTOUTTIME END) OUTTIME
FROM
(SELECT ROW_NUMBER() OVER(PARTITION BY PRODUCTNAME,PRODUCTPROCESSEDMACHINENAME ORDER BY TIMEKEY) RN,TIMEKEY,PRODUCTNAME,PRODUCTPROCESSEDMACHINENAME,PRODUCTINTIME,PRODUCTOUTTIME
FROM MES_CT_PRODUCTTRACEHISTORY ${if(len(ddbDataPart)==0,"","PARTITION ("+ddbDataPart+")")},MN1
AND PRODUCTOUTTIME >= REPLACE('${dtdDateStart}','-','')||REPLACE('${ddbTimeStart}','-','')
AND PRODUCTOUTTIME <= REPLACE('${dtdDateEnd}','-','')||REPLACE('${ddbTimeEnd}','-','')
${if(len(ddcMachineName)==0,"","AND MES_CT_PRODUCTTRACEHISTORY.MACHINENAME IN ('"+ddcMachineName+"')")}
AND PRODUCTPROCESSEDMACHINENAME = MN1.MACHINENAME
${if(len(ddcProductspec)==0,"","AND PRODUCTSPECNAME IN ('"+ddcProductspec+"')")}
${if(len(ddcOperation)==0,"","AND PROCESSOPERATIONNAME IN ('"+ddcOperation+"')")}
${if(RIGHT(TRIM(ddcUnit),3)= 'COL',"","AND COMPONENTTYPE <>'ComponentGlassBuffer'")}
${if(RIGHT(TRIM(ddcUnit),3)= 'COL',"","AND COMPONENTTYPE <>'ComponentPanelByBuffer'")}
UNION ALL
FROM MES_CT_PRODUCTTRACEHISTORY ${if(len(ddbDataPart)==0,"","PARTITION ("+ddbDataPart+")")},MN2
AND PRODUCTINTIME >= REPLACE('${dtdDateStart}','-','')||REPLACE('${ddbTimeStart}','-','')
AND PRODUCTINTIME <= REPLACE('${dtdDateEnd}','-','')||REPLACE('${ddbTimeEnd}','-','')
AND PRODUCTPROCESSEDMACHINENAME = MN2.MACHINENAME
ORDER BY TIMEKEY
/*计算优化时间差*/
,KK AS
(SELECT ROW_NUMBER() OVER(PARTITION BY PRODUCTPROCESSEDMACHINENAME,RN ORDER BY natureTT) RNB
    ,natureTT
,RN
FROM
(SELECT AA.RN,AA.TIMEKEY,AA.PRODUCTPROCESSEDMACHINENAME,ROUND(AA.SECON-(CASE WHEN CC.T4result>0 THEN CC.T4result WHEN CC.T4result IS NULL THEN 0 ELSE 0 END )-(CASE WHEN DD.T1result>0 THEN DD.T1result WHEN DD.T1result IS NULL THEN 0 ELSE 0 END ),2) AS natureTT
FROM
(SELECT RN,TO_DATE(SUBSTR(TIMEKEY,0,14),'yyyy-MM-dd HH24:mi:ss') TIMEKEY
,PRODUCTNAME
,ROUND((TO_DATE(SUBSTR(OUTTIME,0,14),'yyyy-MM-dd HH24:mi:ss')-LAG(TO_DATE(SUBSTR(OUTTIME,0,14),'yyyy-MM-dd HH24:mi:ss'),1,NULL) OVER(PARTITION BY PRODUCTPROCESSEDMACHINENAME,RN ORDER BY OUTTIME))* 24 * 60 * 60,2) AS SECON
FROM PTH
) AA
/*匹配T4时间*/
LEFT JOIN
(SELECT ROW_NUMBER() OVER(PARTITION BY MATERIALNAME,UNITNAME ORDER BY TIMEKEY) RN,BB.TIMEKEY,BB.MATERIALNAME,BB.UNITNAME,TO_NUMBER(BB.result)  AS T4result
FROM(
SELECT (CASE WHEN  regexp_like(result, '[[:alpha:]]') THEN '0' ELSE RESULT END)RESULT,b.TIMEKEY,b.UNITNAME,b.MATERIALNAME FROM RPTMGR.SPC_DCPROCESSDATARESULT ${if(len(ddbDataPart)==0,"","PARTITION ("+ddbDataPart+")")} a LEFT JOIN RPTMGR.SPC_DCDATA ${if(len(ddbDataPart)==0,"","PARTITION ("+ddbDataPart+")")} b  ON a.DCDATAID=b.DCDATAID
AND b.PARTITIONKEY >= REPLACE('${dtdDateStart}','-','')
AND b.PARTITIONKEY <= REPLACE('${dtdDateEnd}','-','')
AND b.TIMEKEY  >= REPLACE('${dtdDateStart}','-','')||REPLACE('${ddbTimeStart}','-','')
AND b.TIMEKEY  <= REPLACE('${dtdDateEnd}','-','')||REPLACE('${ddbTimeEnd}','-','')
AND b.UNITNAME IN ('${ddcUnit}')
AND a.ITEMNAME IN ('T4','STTT4')
AND a.PARTITIONKEY=b.PARTITIONKEY
UNION ALL
SELECT (CASE WHEN regexp_like(result, '[[:alpha:]]') THEN '0' ELSE RESULT END)RESULT,b.TIMEKEY,b.UNITNAME,b.MATERIALNAME FROM RPTMGR.SPC_DCMEASUREDATARESULT ${if(len(ddbDataPart)==0,"","PARTITION ("+ddbDataPart+")")} a LEFT JOIN RPTMGR.SPC_DCDATA ${if(len(ddbDataPart)==0,"","PARTITION ("+ddbDataPart+")")} b ON a.DCDATAID=b.DCDATAID
AND a.ITEMNAME = 'T4'
)BB
)CC
ON AA.PRODUCTNAME=CC.MATERIALNAME AND CC.UNITNAME=AA.PRODUCTPROCESSEDMACHINENAME AND AA.RN=CC.RN AND ROUND(AA.SECON-NVL(CC.T4result,0)) >0
/*匹配T1时间*/
LEFT JOIN
(SELECT ROW_NUMBER() OVER(PARTITION BY MATERIALNAME,UNITNAME ORDER BY TIMEKEY) RN,BB.TIMEKEY,BB.MATERIALNAME,BB.UNITNAME,TO_NUMBER(BB.result) AS T1result
FROM
(SELECT (CASE WHEN  regexp_like(result, '[[:alpha:]]') THEN '0' ELSE RESULT END)RESULT,b.TIMEKEY,b.UNITNAME,b.MATERIALNAME FROM RPTMGR.SPC_DCPROCESSDATARESULT ${if(len(ddbDataPart)==0,"","PARTITION ("+ddbDataPart+")")} a LEFT JOIN RPTMGR.SPC_DCDATA ${if(len(ddbDataPart)==0,"","PARTITION ("+ddbDataPart+")")} b ON a.DCDATAID=b.DCDATAID
AND a.ITEMNAME IN ('T1','STT1')
UNION ALL
AND a.ITEMNAME = 'T1'
)BB
)DD
ON AA.PRODUCTNAME=DD.MATERIALNAME AND DD.UNITNAME=AA.PRODUCTPROCESSEDMACHINENAME AND AA.RN=DD.RN AND ROUND(AA.SECON-NVL(DD.T1result,0)) >0
AND AA.SECON >0
AND ABS(AA.TIMEKEY -NVL(TO_DATE(SUBSTR(CC.TIMEKEY,0,14),'yyyy-mm-dd hh24:mi:ss'),AA.TIMEKEY)) <=0.1
AND ABS(AA.TIMEKEY -NVL(TO_DATE(SUBSTR(DD.TIMEKEY,0,14),'yyyy-mm-dd hh24:mi:ss'),AA.TIMEKEY)) <=0.1
ORDER BY TIMEKEY
AND natureTT > 0
ORDER BY PRODUCTPROCESSEDMACHINENAME,natureTT
/*前后排除5%数据,剩余求均值*/
SELECT PRODUCTPROCESSEDMACHINENAME,AVG(natureTT) CapaTT
FROM
(SELECT CASE WHEN MOD(RN,2)=1
THEN (CASE WHEN KK.PRODUCTPROCESSEDMACHINENAME IN ('A4PIL01-TRF5','A4PIL04-TRF5','A4PIL05-TRF5','A4PIL06-TRF5','A4PIL07-TRF5','A4PIL09-TRF5','A4PIL12-TRF5','A4PIL13-TRF5','A4PIL14-TRF5','A4PIL15-TRF5') THEN  KK.PRODUCTPROCESSEDMACHINENAME||'(EXPO)'
WHEN KK.PRODUCTPROCESSEDMACHINENAME IN ('A4PIL02-TRF5','A4PIL03-TRF5','A4PIL08-TRF5','A4PIL10-TRF5','A4PIL11-TRF5','A4PIL16-TRF5') THEN  KK.PRODUCTPROCESSEDMACHINENAME||'(EXPA)'
WHEN KK.PRODUCTPROCESSEDMACHINENAME IN ('A4PIL02-TRF8','A4PIL03-TRF8','A4PIL08-TRF8','A4PIL10-TRF8','A4PIL11-TRF8','A4PIL16-TRF8') THEN  KK.PRODUCTPROCESSEDMACHINENAME||'(EXPB)'
WHEN KK.PRODUCTPROCESSEDMACHINENAME IN ('A4PIL09-TRF9','A4PIL10-TRF9','A4PIL11-TRF9','A4PIL12-TRF9','A4PIL13-TRF9','A4PIL14-TRF9') THEN  KK.PRODUCTPROCESSEDMACHINENAME||'(OVEN)'
WHEN KK.PRODUCTPROCESSEDMACHINENAME LIKE 'F4PHL%TR05' THEN  KK.PRODUCTPROCESSEDMACHINENAME||'(OVEN)'
ELSE KK.PRODUCTPROCESSEDMACHINENAME END)
WHEN MOD(RN,2)=0
THEN (CASE WHEN KK.PRODUCTPROCESSEDMACHINENAME IN('A4PIL01-TRF5','A4PIL04-TRF5','A4PIL05-TRF5','A4PIL06-TRF5','A4PIL07-TRF5') THEN  KK.PRODUCTPROCESSEDMACHINENAME||'(TITL)'
WHEN KK.PRODUCTPROCESSEDMACHINENAME IN ('A4PIL02-TRF5','A4PIL03-TRF5','A4PIL08-TRF5','A4PIL10-TRF5','A4PIL11-TRF5','A4PIL16-TRF5') THEN  KK.PRODUCTPROCESSEDMACHINENAME||'(TRF6)'
WHEN KK.PRODUCTPROCESSEDMACHINENAME IN ('A4PIL02-TRF8','A4PIL03-TRF8','A4PIL08-TRF8','A4PIL10-TRF8','A4PIL11-TRF8','A4PIL16-TRF8') THEN  KK.PRODUCTPROCESSEDMACHINENAME||'(TRF6)'
WHEN KK.PRODUCTPROCESSEDMACHINENAME IN ('A4PIL09-TRF5','A4PIL12-TRF5','A4PIL13-TRF5','A4PIL14-TRF5','A4PIL15-TRF5') THEN KK.PRODUCTPROCESSEDMACHINENAME||'(EETT)'
WHEN KK.PRODUCTPROCESSEDMACHINENAME IN ('A4PIL09-TRF9','A4PIL10-TRF9','A4PIL11-TRF9','A4PIL12-TRF9','A4PIL13-TRF9','A4PIL14-TRF9') THEN KK.PRODUCTPROCESSEDMACHINENAME||'(AOIL)'
WHEN KK.PRODUCTPROCESSEDMACHINENAME LIKE 'F4PHL%TR05' THEN  KK.PRODUCTPROCESSEDMACHINENAME||'(AOI1)'
END PRODUCTPROCESSEDMACHINENAME
,natureTT,RNB,MAXTT
FROM KK
LEFT JOIN (SELECT PRODUCTPROCESSEDMACHINENAME,MAX(RNB) MAXTT FROM KK GROUP BY PRODUCTPROCESSEDMACHINENAME,RN) KK2 ON KK.PRODUCTPROCESSEDMACHINENAME=KK2.PRODUCTPROCESSEDMACHINENAME
AND RNB >= MAXTT*0.05
AND RNB <= MAXTT*0.95
SQL如上,执行时间接近2分钟,是否有好的优化方向减少查询时间,分区与索引都尽可能的用上了,求大神指点
FineReport 用户c2750520 发布于 2020-12-23 09:54
luojian0323Lv7资深互助
发布于2020-12-23 09:57
写存储过程把数据存储到静态表中
没有其他办法,就你这sql
我想也没有多大优化空间。
  • 用户c2750520 用户c2750520(提问者) 因为boss随时都有可能查询最新的数据,存储过程按分钟级别执行,内存占用方面也是问题
    2020-12-23 10:12
  • luojian0323 luojian0323 回复 用户c2750520(提问者) 你不写存储过程,boss打开你一个报表要2分钟 你是不想干了吧。
    2020-12-23 10:12
  • luojian0323 luojian0323 回复 用户c2750520(提问者) 需要实时的数据,往往不需要复杂计算  需要复杂计算的往往不需要实时
    2020-12-23 10:13
  • 用户c2750520 用户c2750520(提问者) 回复 luojian0323 这是生产类的数据,每小时会有数万条数据,原始数据不计算没法报表汇总
    2020-12-23 10:22
  • luojian0323 luojian0323 回复 用户c2750520(提问者) 研究一下别的etl工具吧  一般的sql查询解决不了你的需求。
    2020-12-23 10:24
沉默的反补Lv6中级互助
发布于2020-12-23 09:57
三百多行一个字段的过滤写了七八遍。。。不慢天理难容~~
  • 用户c2750520 用户c2750520(提问者) 有好的方式改善吗
    2020-12-23 10:09
  • 沉默的反补 沉默的反补 回复 用户c2750520(提问者) 1.数据量过大,避免超大量数据一次性查询.如果数据量很量,用分页查询,或者用条件属性设置分页. 2.空白单元格不合理父格导致的笛卡尔积,不要有空白单元格,报表中有不同数据集数据时,左父格,上父格,设置明确 3.类Excel制作的模板,尽量避免,条件属性,单元格公式(特别是sql公式),单元格数据过滤,尽量少设置. 4.插入的图表或者图片不宜过多. 5.填报控件较多时,避免控件直接显示在报表中,控件的数据字典要尽量优化,不宜查询过慢. 6.报表元素过多,扩展图表使用过于频繁,尽量避免. 7.过大过多的背景图片,尽量避免,不要觉得几百KB不大,告诉你,一样卡.
    2020-12-23 10:12
小县城Lv4见习互助
发布于2020-12-23 10:16
单独写存储过程。弄个定时任务,定时把资料跑出来。把结果都插入到一个表里。每次查询就查询这个表呗。和领导说每半个小时或者一个小时更新一次资料呗。
  • 用户c2750520 用户c2750520(提问者) 要从4个大表中捞出数据计算,情况是根据查询时间的不同,如果按小时提前计算出结果存储,查询多个小时甚至天的数据时,一次性计算出的结果,和每小时查询的结果汇总会有数据差距,因为涉及到数据抛出,一次抛出和多次抛出情况不相同
    2020-12-23 10:39
DeepWhiteLv5见习互助
发布于2020-12-23 10:39
要不把with as 改成select into 试一下?
  • 用户c2750520 用户c2750520(提问者) 这样写是为了提高一些可读性,方便其他人能看懂,select into 我尝试一下
    2020-12-23 10:41
  • 496浏览人数
  • 最后回答于:2020-12-23 10:39
