语句问题,哪里出错了
(if($p1=a,sql("sss","select  * from  a ",1),sql("sss","select  *  from  b ",1),1))
FineReport 15764373317 发布于 2020-12-27 10:10
发布于2020-12-27 10:13
if($p1='a',sql("sss","select  * from  a ",1),sql("sss","select  *  from  b ",1))
  • 220浏览人数
  • 最后回答于:2020-12-27 10:13
