导出按钮调用JS,导出EXCEL文件成功,但是打开报错,一串的JS错误,求大神!!
6个参数控件(org_list_1,org_list_3,var_d_date,var_status,var_start_time,var_end_time),
各自绑定了数据源,导出按钮(out_put)自定义js如下:
var var_org_list_1 = this.options.form.getWidgetByName("org_list_1").getValue();
var_org_list_1 = "\"" + var_org_list_1 + "\"";
var var_org_list_3 = this.options.form.getWidgetByName("org_list_3").getValue();
var_org_list_3 = "\"" + var_org_list_3 + "\"";
var var_d_date = this.options.form.getWidgetByName("d_date").getValue();
var_d_date = "\"" + var_d_date + "\"";
var var_status = this.options.form.getWidgetByName("status").getValue();
var_status = "\"" + var_status + "\"";
var var_start_time = this.options.form.getWidgetByName("start_time").getValue();
var_start_time = "\"" + var_start_time + "\"";
var var_end_time = this.options.form.getWidgetByName("end_time").getValue();
var_end_time = "\"" + var_end_time + "\"";
var paramStr = encodeURIComponent(
 "{org_list_1:" + var_org_list_1 + ",org_list_3:" + var_org_list_3 + ",d_date:" + var_d_date + ",status:" + var_status + ",start_time:" + var_start_time + ",end_time:" + var_end_time + "}")
var colNames = encodeURIComponent("")
_g().directExportToExcel("output", "数据汇总表", paramStr, colNames);
导出后提示保存EXCEL文件,但是打开文件报错,
catTiger 发布于 2021-1-26 11:00 (编辑于 2021-1-26 11:09)
发布于2021-8-10 16:59
你这个是本身查询就报错了,然后把报错页面导出了。。。
故笙I诉离歌Lv3见习互助
发布于2021-1-26 11:07
格式改成.xls 03版的格式试试看
不必大咖Lv4见习互助
发布于2021-8-16 10:11
 var aaa= getQueryVariable('aaa_id');
 var bbb_id= getQueryVariable('bbb_id');
var url=(        "url网址"+"&aaa_id="+aaa_id+"&bbb_id="+bbb_id);
window.location=(FR.cjkEncode(url+"&format=excel"));
试试这种代码
  • 567浏览人数
  • 最后回答于:2021-8-16 10:11
