可以通过js控制拖拽来获得选中了哪些单元格吗
汤姆喵喵喵 发布于 2021-2-5 11:56
汤姆喵喵喵Lv3见习互助
发布于2021-2-28 09:33
在Web属性里引入了test.js,代码如下:
window.onload = function() { var _area = document.createElement("div"); _area.style.display = "none"; _area.style.position = "absolute"; _area.style.width = "0px"; _area.style.height = "0px"; _area.style.fontSize = "0px"; _area.style.margin = "0px"; _area.style.padding = "0px"; _area.style.opacity = "0.5"; _area.style.top = "0px"; _area.style.left = "0px"; _area.style.filter = "alpha(opacity:50)"; _area.style.border = "1px dashed rgb(0,0,0)"; _area.style.zIndex = "1000"; var m_down = 0 ; var start ={x:0,y:0}; var _containner = document.getElementsByClassName("sheet-container")[0]; _containner.appendChild(_area); function getPosition(){ var e = window.event || arguments[0]; return { x: e.pageX || (e.clientX + (document.documentElement.scrollLeft || document.body.scrollLeft)), y: e.pageY - 71 || (e.clientY + (document.documentElement.scrollTop || document.body.scrollTop)) }; } function hasClass(elem, cls) { cls = cls || ''; if (cls.replace(/\s/g, '').length == 0) return false; //当cls没有参数时,返回false return new RegExp(' ' + cls + ' ').test(' ' + elem.className + ' '); } function addClass(ele, cls) { if (!hasClass(ele, cls)) { ele.className = ele.className == '' ? cls : ele.className + ' ' + cls; } } function removeClass(elem, cls) { if (hasClass(elem, cls)) { var newClass = ' ' + elem.className.replace(/[\t\r\n]/g, '') + ' '; while (newClass.indexOf(' ' + cls + ' ') >= 0) { newClass = newClass.replace(' ' + cls + ' ', ' '); } elem.className = newClass.replace(/^\s+|\s+$/g, ''); } } function isIn(selDiv, region){ var st = _containner.scrollTop; var s_top = parseInt(selDiv.offsetTop); var s_left = parseInt(selDiv.offsetLeft) ; var s_right = s_left + parseInt(selDiv.offsetWidth); var s_bottom = s_top + parseInt(selDiv.offsetHeight); var r_top = parseInt(region.offsetTop) + parseInt(_containner.scrollTop); var r_left = parseInt(region.offsetLeft) + parseInt(_containner.scrollLeft); var r_right = r_left + parseInt(region.offsetWidth); var r_bottom = r_top + parseInt(region.offsetHeight); var t = Math.max(s_top, r_top); var r = Math.min(s_right, r_right); var b = Math.min(s_bottom, r_bottom); var l = Math.max(s_left, r_left); if (b > t + 5 && r > l + 5) { return selDiv; } else { return null; } }; _containner.onmousedown = function(){ var e = window.event || arguments[0]; start = getPosition(e); // alert(start.x + ":" + start.y); m_down = 1 ; }; _containner.onmouseup = function(){ _area.style.display = "none"; m_down = 0 ; }; _containner.onmousemove = function(){ var e = window.event || arguments[0]; var divs = document.getElementsByClassName("fh"); if(m_down){ _area.style.display = "block"; _area.style.left = Math.min(start.x, getPosition(e).x) + "px";  _area.style.top = Math.min(start.y, getPosition(e).y) + "px"; _area.style.width = Math.abs(start.x - getPosition(e).x) + "px"; _area.style.height = Math.abs(start.y - getPosition(e).y) + "px"; for(var i = 0; i<divs.length;i++){ if(isIn(divs[i], _area)){ addClass(divs[i], "sel"); } else { removeClass(divs[i], "sel"); } } } }; };
发布于2021-2-5 12:29
这个不行,单个单元格是可以的
  • 566浏览人数
  • 最后回答于:2021-2-28 09:33
