跑马灯隐藏边框
使用官方文档的代码,
window.flag1 = true;
var self1 = this;
//鼠标悬停,滚动停止
setTimeout(function() {
$("div[widgetname=REPORT000]").find(".frozen-center").mouseover(function() {
window.flag1 = false;
//鼠标离开,继续滚动
$("div[widgetname=REPORT000]").find(".frozen-center").mouseleave(function() {
var old = -1;
var interval = setInterval(function() {
if (!self1.isVisible()) {
return;
if (window.flag1) {
currentpos1 = $("div[widgetname=REPORT000]").find(".frozen-center")[0].scrollTop;
if (currentpos1 == old && 0!=currentpos1) {
$("div[widgetname=REPORT000]").find(".frozen-center")[0].scrollTop = 0;
} else {
old = currentpos1;
//以25ms的速度每次滚动1.5PX
$("div[widgetname=REPORT000]").find(".frozen-center")[0].scrollTop = currentpos1 + 1.5;
25);
1000);
FineReport MKERA 发布于 2021-2-18 15:30
ScyalcireLv7中级互助
发布于2021-2-18 15:33(编辑于 2021-2-18 15:34)
    var $report = $("div[widgetname=REPORT6]");
    //获取对应report的div元素
    var $scroll = $report.find("#frozen-center");
    //获取对应report的div元素的滚动块元素,冻结为#frozen-center,未冻结且未安装自定义滚动条插件为.reportContent,未冻结且安装了自定义滚动条插件为.scrollDiv
    var flag = window.flag0;
    //设置全局变量flag,每个报表块需保证各不相同
    $report.find("#frozen-center").css('overflow-x', 'hidden');
    $report.find("#frozen-center").css('overflow-y', 'hidden');
    $report.find("#frozen-north").css('overflow-x', 'hidden');
    $report.find("#frozen-north").css('overflow-y', 'hidden');
    //冻结情况下隐藏滚动条
    $report.find(".reportContent").css('overflow-y', 'hidden');
    $report.find(".reportContent").css('overflow-x', 'hidden');
    //非冻结情况下隐藏滚动条
    flag = true;
    //定义全局参数flag,用来控制滚动的暂停和继续
//    $scroll.mouseover(function() {
//        flag = false;
    //鼠标悬浮,滚动停止
//    $scroll.mouseleave(function() {
//        flag = true;
    //鼠标离开,继续滚动
    var old = -1;
        if (flag) {
            currentpos = $scroll[0].scrollTop;
            //获取距顶部距离
            if (currentpos == old) {
                $scroll[0].scrollTop = 0;
                //若已到达底部,则重置
            } else {
                old = currentpos;
                $scroll[0].scrollTop = currentpos + 1.5;
                //若未到达底部,则向下移动1.5像素
    }, 35);
    //以25ms的频率执行
}, 500);
看注释   冻结非冻结都适用  直接复制代码 然后第二行修改你的report名称
luojian0323Lv7资深互助
发布于2021-2-18 15:33
setInterval(function() {     //隐藏报表块REPORT0的滚动条     $("div[widgetname=REPORT000]").find(".frozen-north")[0].style.overflow = "hidden";     $("div[widgetname=REPORT000]").find(".frozen-center")[0].style.overflow = "hidden"; }, 1000);
  • 444浏览人数
  • 最后回答于:2021-2-18 15:34
