这个sql怎么实现按dj汇总数据的,dj为1的是所有数据加起来的,等级为2的是它下面的3和4加起来的,等级3是他下面的4加起来的,dj这个字段是自己根据xmdm拆出来的,一共四类,dj怎么拆比较好呢,只能在sql里面写微信截图_20210326162621.png
冰雨咖啡 发布于 2021-3-26 16:30
冰雨咖啡Lv5见习互助
发布于2021-3-26 17:05
with ds1 as (
select t1.xmdm,t1.xmmc,loccurramt
from SJYS t1
left join SJYS_DT1 t2 on t1.id=t2.mainid
left join SJYS_KMDM t3 on t2.erpxmdm=t3.glacct2
where t3.fiscalyear=2020 and t3.companycode='W68' and t3.postperiod=1
ds2 as (
ds1.loccurramt
from SJYS t1
left join ds1 on t1.xmdm=ds1.xmdm
order by t1.xh
ds3 as (
select 'FY00' xmdm,sum(loccurramt) loccurramt from ds2
union all
select substr(xmdm,1,2)||'00' xmdm,sum(loccurramt) loccurramt from ds2
where xmdm <> 'FY00'
group by substr(xmdm,1,2)
union all
select substr(xmdm,1,4) xmdm,sum(loccurramt) loccurramt from ds2
where substr(xmdm,3,2) <> '00'
group by substr(xmdm,1,4)
union all
select substr(xmdm,1,6) xmdm,sum(loccurramt) loccuramt from ds2 where length(xmdm)=6
group by substr(xmdm,1,6)
select ds3.xmdm,t1.xmmc,ds3.loccurramt from ds3
join SJYS t1 on t1.xmdm=ds3.xmdm
order by t1.xh
已实现
  • 0关注人数
  • 396浏览人数
  • 最后回答于:2021-3-26 17:05
