sql拼接问题?
如下:
select * from 订单 where 1=1 , 现在参数是通过界面复选框框传值,如果参数是1,2,则在where 后拼接 a=1 条件,select * from 订单 where 1=1 and a=1;
否则为:
select * from  订单 where 1=1 and b=1
FineReport Qian同学 发布于 2021-4-2 15:57 (编辑于 2021-4-2 16:22)
烟尘Lv6高级互助
发布于2021-4-2 15:59(编辑于 2021-4-2 16:27)
where 1=1
${if(参数==1||参数==2," and a=1"," and b=1")}
复选框返回字符串:
${if(find("1",参数)>0||find("2",参数)>0," and a=1"," and b=1")}
复选框返回数组:
${if(inarray(1,参数)>0||inarray(2,参数)>0," and a=1"," and b=1")}
建议返回数组,字符串的话如果有12判断会出错
  • Qian同学 Qian同学(提问者) 如果参数是复选框呢,,传过来的是字符串 1,2,3 不能用==了吧
    2021-04-02 16:18
  • 烟尘 烟尘 回复 Qian同学(提问者) ${if(find(\"1\",参数)>0||find(\"2\",参数)>0,\" and a=1\",\" and b=1\")}
    2021-04-02 16:23
  • 烟尘 烟尘 回复 Qian同学(提问者) 要保证其他选项没有1,就是10,11,12之类的都没有,返回字符串才能正确判断
    2021-04-02 16:28
  • Qian同学 Qian同学(提问者) 其实我复选框返回的都是中文,用字符串返回应该没有问题吧
    2021-04-02 16:36
  • 烟尘 烟尘 回复 Qian同学(提问者) 只要没有类似于【a】、【ab】这样的一项包含另一项全部的情况就没问题
    2021-04-02 16:39
发布于2021-4-2 16:01
${if(or(find("1",p)>0,find("2",p)>0)," and a=1"," and b=1")}
被子Lv7见习互助
发布于2021-4-2 16:05
--方法一 ${ if(参数=1," select * from 订单 where 1=1 and a=1 "," select * from  订单 where 1=1 and b=1 ") } --方法二 select * from 订单 where 1=1 ${if(参数==1||参数==2," and a=1"," and b=1")}
    2021-04-02 16:23
梦想的初衷Lv7初级互助
发布于2021-4-2 16:07
可以试下这个
${if(参数=="1","
SELECT
FROM 表
where
条件1
${if(参数="2","
SELECT
FROM 表
where
条件2
    2021-04-02 16:23
  • 梦想的初衷 梦想的初衷 回复 Qian同学(提问者) ${if(and(参数=\"\",参数=\"2\"),\" SELECT * FROM 表 where 条件1 \",\" \")}
    2021-04-02 16:32
  • 梦想的初衷 梦想的初衷 回复 Qian同学(提问者) 刚试过前面加个and 就可以
    2021-04-02 16:33
  • Qian同学 Qian同学(提问者) 回复 梦想的初衷 也非常感谢您
    2021-04-02 16:37
  • 572浏览人数
  • 最后回答于:2021-4-2 16:27
