windows7系统mysql连接不上但驱动配置好了报错
严重:13:27:26 TestConnection-50-worker-1 ERROR [standard] 错误代码:31300012 创建数据连接失败: The server time zone value '�й���׼ʱ��' is unrecognized or represents more than one time zone. You must configure either the server or JDBC driver (via the 'serverTimezone' configuration property) to use a more specifc time zone value if you want to utilize time zone support.
yikefu 发布于 2021-4-3 14:14 (编辑于 2021-4-3 14:16)
悬赏:8 F币 + 添加悬赏
发布于2021-4-3 14:22(编辑于 2021-4-3 14:33)
MySQL8.0数据连接-https://help.fanruan.com/finereport/doc-view-2863.html
MySQL8数据连接插件-https://help.fanruan.com/finereport/doc-view-3751.html
—— 乱码和「字符编码」有关系,驱动更新后,重启服务,相关信息严格按照文档变更!
  • 464浏览人数
  • 最后回答于:2021-4-3 14:33
