报表查询时,有六个控件,我想实现最后两个控件不选也能都查询到
FineReport lww19959 发布于 2018-11-19 09:05
共5回答
touyuan001Lv6中级互助
发布于2018-11-19 09:10(编辑于 2018-11-19 14:51)
数据集里面那两个的条件调整成下成的格式,就可以了
例如 A B 两个参数控件
那么就在where条件后面加上
${if(len(A)==0,""," and 字段1='"+A+"'")}
${if(len(B)==0,""," and 字段2='"+B+"'")}
select *
  from (select a.*, b.dept_id, b.dept_alias
          from [       bjchbi ] . [ dbo ] . [ dm_lab_busi_qty_tat_fact ] a,
               dimdept b
         where a.request_department_id = b.dept_id) c
 where rport_date between '${sj1}' and '${sj2}'
 ${if(len(ks) == 0, "", "and c.dept_alias in ('" + ks + "')") }
 ${if(len(xmmc) == 0, "", "and c.project_name in ('" + xmmc + "')") }
 ${if(len(mzzy) == 0,"", "and c.encounter_type_id in ('" + mzzy + "')") }
 ${if(len(yxjb) == 0, "","and c.priority_indicator in ('" + yxjb + "')") }
  • lww19959 lww19959(提问者) 我想问一下字段1,2是什么啊
    2018-11-19 11:23
  • touyuan001 touyuan001 回复 lww19959(提问者) 你查询条件里面的要过滤的列名
    2018-11-19 11:27
  • lww19959 lww19959(提问者) 回复 touyuan001 老哥儿,我现在where后面不是等于,用的in模糊查询,怎么调整啊?
    2018-11-19 14:38
  • touyuan001 touyuan001 回复 lww19959(提问者) select * from (select a.*, b.dept_id, b.dept_alias from [ bjchbi ] . [ dbo ] . [ dm_lab_busi_qty_tat_fact ] a, dimdept b where a.request_department_id = b.dept_id) c where rport_date between \'${sj1}\' and \'${sj2}\' ${if(len(ks) == 0, \"\", \"and c.dept_alias in (\'\" + ks + \"\')\") } ${if(len(xmmc) == 0, \"\", \"and c.project_name in (\'\" + xmmc + \"\')\") } ${if(len(mzzy) == 0,\"\", \"and c.encounter_type_id in (\'\" + mzzy + \"\')\") } ${if(len(yxjb) == 0, \"\",\"and c.priority_indicator in (\'\" + yxjb + \"\')\") }
    2018-11-19 14:48
  • touyuan001 touyuan001 回复 lww19959(提问者) 按你图中的语句改了下,当下面那4个参数为空的时候,就不过滤对应内容
    2018-11-19 14:49
axingLv6专家互助
发布于2018-11-19 09:08
下拉框参数为空选择全部-http://help.finereport.com/doc-view-2394.html
No1-王子阳Lv5中级互助
发布于2018-11-19 10:00
以上两位的方法都没有问题,你可以尝试一下。
luhansonLv3见习互助
发布于2018-11-19 10:38
WHERE  字段XX=CASE WHEN '${XXX}' <> '' then '${XXX}' else 字段XX
晓亮Lv7资深互助
发布于2018-11-19 14:55
sql可以用(nvl(参数,'1')='1' or nvl(参数,'1')<>'1'  and 字段条件>参数)
  • 6关注人数
  • 1036浏览人数
  • 最后回答于:2018-11-19 14:55
