这个怎么做参数吧这个db5b833fc3f6a90f1a0ac008a03ff713换成pid 传入
select bb.ENFORCEUNIT,count(bb.pid) as num ,sum(bb.totalWeightGoods) as totalWeightGoods ,sum(bb.aftertotalMass) as aftertotalMass
from  bwsn_basicinfo bb
left join s_project sp on bb.pid =sp.id
left join s_unit su on bb.enforceUnitId =su.id
where (sp.status !="撤销" or sp.status is null) and caseType="联合治超"
and  su.CATALOGROUTE like CONCAT("%","db5b833fc3f6a90f1a0ac008a03ff713","%")
GROUP BY bb.enforceUnitId,bb.ENFORCEUNIT
FineReport sw0414 发布于 2021-4-29 17:18 (编辑于 2021-4-29 17:18)
axingLv6专家互助
发布于2021-4-29 17:25
where (sp.status !='撤销' or sp.status is null) and caseType='联合治超'
and  su.CATALOGROUTE like '%${pid}%'
入海Lv6见习互助
发布于2021-4-29 17:27
and  su.CATALOGROUTE like CONCAT("%","${pid}","%")  这样?
  • 319浏览人数
  • 最后回答于:2021-4-29 17:27
