如何 通过控件传入的参数获取单元的数据 通过时间和重量控件 筛查出数据
select bb.ENFORCEUNIT,count(bb.pid) as num ,sum(bb.totalWeightGoods) as totalWeightGoods ,sum(bb.aftertotalMass) as aftertotalMass
from  bwsn_basicinfo bb
left join s_project sp on bb.pid =sp.id
left join s_unit su on bb.enforceUnitId =su.id
where (sp.status !='撤销' or sp.status is null) and caseType='联合治超'
and  su.CATALOGROUTE like '%${pid}%'
GROUP BY bb.enforceUnitId,bb.ENFORCEUNIT
FineReport sw0414 发布于 2021-4-29 17:31 (编辑于 2021-4-29 17:35)
axingLv6专家互助
发布于2021-4-29 17:45
这也不清楚你哪个字段是单位,哪个字段是时间~
根据下面的文档来配置吧
筛选过滤-https://help.fanruan.com/finereport/doc-view-314.html
数据集参数-https://help.fanruan.com/finereport/doc-view-158.html
  • 269浏览人数
  • 最后回答于:2021-4-29 17:45
