如何通过车货总重控件传入的值查出整个sql,并且在赋值到表单里面
还需要一个时间控件 和车货总重 textEditor0_c 名字为
select bb.ENFORCEUNIT,count(bb.pid) as num ,sum(bb.totalWeightGoods) as totalWeightGoods ,sum(bb.aftertotalMass) as aftertotalMass
from  bwsn_basicinfo bb
left join s_project sp on bb.pid =sp.id
left join s_unit su on bb.enforceUnitId =su.id
where (sp.status !='撤销' or sp.status is null) and caseType='联合治超'
and  su.CATALOGROUTE like '%${pid}%'
GROUP BY bb.enforceUnitId,bb.ENFORCEUNIT
HAVING sum(bb.totalWeightGoods)>="${textEditor0_c}"
FineReport sw0414 发布于 2021-4-29 18:22 (编辑于 2021-4-29 18:23)
axingLv6专家互助
发布于2021-4-29 18:27
and 时间字段 between '${dateStart_c}' and '${dateEnd_c}'
HAVING sum(bb.totalWeightGoods)>='${textEditor0_c}'
sql的字符串要用单引号,不能用双引号,还有一个时间字段帮你加了进来,改成你的实际字段名就好了
  • 309浏览人数
  • 最后回答于:2021-4-29 18:27
