exec一直调oracle存储过程不成功,求助
存储过程参数如下:
procedure sp_ReportResultA(
 in_repid In Varchar2,
     in_gh In Varchar2,
     in_ksrq In Date,
     in_jsrq In Date,
     in_DBRQ In Varchar2,
     in_DBMONTHS In Number,
     in_cols In Varchar2,
     in_wcols In Varchar2,
     in_wvals In Varchar2,
     in_sHavc In Varchar2,
     in_sHave In Varchar2,
     in_Var   In Varchar2,
     in_Val   In Varchar2,
     in_dg    In Varchar2,
     in_ord  In Varchar2,
     out_repA Out SYS_REFCURSOR
     ) Is
exec写法
set nocount on exec USEREPORT.SP_REPORTRESULT '${in_repid}','${in_gh}','${in_ksrq}','${in_jsrq}','${in_DBRQ}','${in_DBMONTHS}','${in_cols}','${in_wcols}','${in_wvals}','${in_sHavc}','${in_sHave}','${in_Var}','${in_Val}','${in_dg}','${in_ord}',?
FineReport elaiza 发布于 2021-5-18 10:39 (编辑于 2021-5-18 10:43)
悬赏:6 F币 + 添加悬赏
elaizaLv6初级互助
发布于2021-11-23 08:47
--- 采用call方法调用储存过程,使用 ?来接收返回的游标
{call SP_REPORTRESULTD
'COM0319',-- in_repidc
'${G_Operator}',-- in_oper
'${开始日期}',-- in_startdate
'${结束日期}',-- in_enddate
'',-- in_contrastsdate
'',-- in_contrastedate
'C_ONSALE_30SKU;C_ONSALE_UNITED_30SKU;C_ONSALE_ININV_30SKU;C_ONSALE_NOINV_30SKU;C_STOPSALE_30SKU;C_STOPSALE_UNITED_30SKU;C_STOPSALE_ININV_30SKU;C_STOPSALE_NOINV_30SKU',-- in_cols
'C_STORE_AREA;C_STORE_ID;C_TCCODE;C_BCATCODE',-- in_wcols
'${areas};${stores};${tccodes};${bcatcodes}',-- in_wvals
'',-- in_shavc
'',-- in_shave
'',-- in_var
'',-- in_val
'',-- in_dg
'',-- in_ord
发布于2021-11-22 18:08
调用存储过程-https://help.finereport.com/finereport9.0/doc-view-1438.html
  • 614浏览人数
  • 最后回答于:2021-11-23 08:47
