sql里面判断传入的这个时间控件的值,怎么判断控件有值的时候,才使用这个条件?
SELECT
CASE WHEN
t1.areaCode THEN
( SELECT sc.areaName FROM s_citycounty sc WHERE sc.areaCode = t1.areaCode )
END AS areaName,
t1.countall,
t2.zcall,
t2.anjuan,
t3.lhzctall,
t3.xzchjds,
t3.czjcd,
t1.penalty AS penalty1,
t2.penalty AS penalty2,
t3.penalty AS penalty3
FROM
SELECT
substr( bb.areaCode, 1, 4 ) AS areaCode,
count( bci.id ) AS countall,
sum( bb.penalty ) AS penalty
FROM
s_project sp
LEFT JOIN bwsn_count_integrity bci ON sp.id = bci.pid
LEFT JOIN bwsn_basicinfo bb ON sp.id = bb.pid
WHERE
bb.ishistory = 1
AND bb.historytype = "案件上传"
AND sp.STATUS = "结案"
AND DATE_FORMAT(sp.createTime,'%Y-%m-%d') >="${dateEnd_c_c}"
AND DATE_FORMAT(sp.createTime,'%Y-%m-%d') <="${dateStart_c_c}"
AND DATE_FORMAT(sp.endTime,'%Y-%m-%d')>="${dateEnd_c_c_c}"
AND DATE_FORMAT(sp.endTime,'%Y-%m-%d')<="${dateStart_c_c_c}"
GROUP BY
) t1
LEFT JOIN (
SELECT
count( bci.id ) AS zcall,
sum( bci.num & 1 = 1 ) AS anjuan,
FROM
s_project sp
WHERE
bb.ishistory = 1
AND bb.caseType = "治超"
GROUP BY
) t2 ON t1.areaCode = t2.areaCode
LEFT JOIN (
SELECT
count( bci.id ) AS lhzctall,
sum( bci.num & 2 = 2 ) AS xzchjds,
sum( bci.num & 4 = 4 ) AS czjcd,
FROM
s_project sp
WHERE
bb.ishistory = 1
AND bb.caseType = "联合治超"
GROUP BY
) t3 ON t1.areaCode = t3.areaCode
FineReport sw0414 发布于 2021-5-19 09:36 (编辑于 2021-5-19 09:38)
xiaomingyiLv6中级互助
发布于2021-5-19 09:38(编辑于 2021-5-19 10:45)
${if(len(dateEnd_c_c)=0,""," AND DATE_FORMAT(sp.createTime,'%Y-%m-%d') >='"+dateEnd_c_c+"' ")}
  • sw0414 sw0414(提问者) 报错了
    2021-05-19 10:09
  • xiaomingyi xiaomingyi 回复 sw0414(提问者) 报什么错?你看我上传的图,我们平时就是这么写的
    2021-05-19 10:46
177741977Lv6初级互助
发布于2021-5-19 09:39
${if(len(传入参数)==0,"","xxx")}
  • 906浏览人数
  • 最后回答于:2021-5-19 10:45
