FineBI抽数失败
用FineBI抽数时总是失败,磁盘空间200G
sql直接是select * from TB
TB总数据量大概有1000W行,mysql
失败日志如下图:
linux上unlimit -a
core file size          (blocks, -c) 0
data seg size           (kbytes, -d) unlimited
scheduling priority             (-e) 0
file size               (blocks, -f) unlimited
pending signals                 (-i) 256712
max locked memory       (kbytes, -l) 64
max memory size         (kbytes, -m) unlimited
open files                      (-n) 1024
pipe size            (512 bytes, -p) 8
POSIX message queues     (bytes, -q) 819200
real-time priority              (-r) 0
stack size              (kbytes, -s) 8192
cpu time               (seconds, -t) unlimited
max user processes              (-u) 256712
virtual memory          (kbytes, -v) unlimited
file locks                      (-x) unlimited
FineBI 朝赟丶 发布于 2021-5-19 14:26 (编辑于 2021-5-19 15:13)
Doctor_WeiLv7中级互助
发布于2021-5-19 14:28
这个是linux的问题,
https://blog.51cto.com/webseven/1632168
小叮珰Lv2见习互助
发布于2021-6-27 14:36
相关文档:Linux最大打开文件数-https://help.fanruan.com/finebi/doc-view-28.html
  • 681浏览人数
  • 最后回答于:2021-6-27 14:36
