在sql里面判断时间控件为啥会报错呢?
SELECT
CASE WHEN
t1.areaCode THEN
( SELECT sc.areaName FROM s_citycounty sc WHERE sc.areaCode = t1.areaCode )
END AS areaName,
t1.countall,
t2.zcall,
t2.anjuan,
t3.lhzctall,
t3.xzchjds,
t3.czjcd,
t1.penalty AS penalty1,
t2.penalty AS penalty2,
t3.penalty AS penalty3
FROM
SELECT
substr( bb.areaCode, 1, 4 ) AS areaCode,
count( bci.id ) AS countall,
sum( bb.penalty ) AS penalty
FROM
s_project sp
LEFT JOIN bwsn_count_integrity bci ON sp.id = bci.pid
LEFT JOIN bwsn_basicinfo bb ON sp.id = bb.pid
WHERE
bb.ishistory = 1
AND bb.historytype = "案件上传"
AND sp.STATUS = "结案"
if(len(dateStart_c_c)=0,"",AND DATE_FORMAT(sp.createTime,'%Y-%m-%d') >="${dateStart_c_c}")
if(len(dateEnd_c_c)=0,"",AND DATE_FORMAT(sp.createTime,'%Y-%m-%d') >="${dateEnd_c_c}")
if(len(dateStart_c_c_c)=0,"",AND DATE_FORMAT(sp.createTime,'%Y-%m-%d') >="${dateStart_c_c_c}")
if(len(dateEnd_c_c_c)=0,"",AND DATE_FORMAT(sp.createTime,'%Y-%m-%d') >="${dateEnd_c_c_c}")
GROUP BY
) t1
LEFT JOIN (
SELECT
count( bci.id ) AS zcall,
sum( bci.num & 1 = 1 ) AS anjuan,
FROM
s_project sp
WHERE
bb.ishistory = 1
AND bb.caseType = "治超"
GROUP BY
) t2 ON t1.areaCode = t2.areaCode
LEFT JOIN (
SELECT
count( bci.id ) AS lhzctall,
sum( bci.num & 2 = 2 ) AS xzchjds,
sum( bci.num & 4 = 4 ) AS czjcd,
FROM
s_project sp
WHERE
bb.ishistory = 1
AND bb.caseType = "联合治超"
GROUP BY
) t3 ON t1.areaCode = t3.areaCode
FineReport sw0414 发布于 2021-5-21 15:15 (编辑于 2021-5-21 15:39)
axingLv6专家互助
发布于2021-5-21 15:21
改成这样
${if(len(dateStart_c_c)=0,"","AND DATE_FORMAT(sp.createTime,'%Y-%m-%d') >='"+dateStart_c_c+"'")}
${if(len(dateEnd_c_c)=0,"","AND DATE_FORMAT(sp.createTime,'%Y-%m-%d') >='"+dateEnd_c_c+"'")}
${if(len(dateStart_c_c_c)=0,"","AND DATE_FORMAT(sp.createTime,'%Y-%m-%d') >='"+dateStart_c_c_c+"'")}
${if(len(dateEnd_c_c_c)=0,"","AND DATE_FORMAT(sp.createTime,'%Y-%m-%d') >='"+dateEnd_c_c_c+"'")}
  • sw0414 sw0414(提问者) 严重:15:28:36 SocketListener0-5 ERROR [root] 报表计算中[Name : 治超案件上传统计表.cpt] [Parameter : {__FIT__ : true[java.lang.Boolean], __LOCALE__ : zh_CN[java.util.Locale], __STREAMCLOSED__ : [java.lang.String], CHECKBOX0 : false[java.lang.Boolean], CMD : parameters_d[java.lang.String], DATEEND_C_C : 2021-04-29[java.lang.String], DATEEND_C_C_C : [java.lang.String], DATESTART_C_C : 2021-05-19[java.lang.String], DATESTART_C_C_C : [java.lang.String], LABEL0_C_C_C_C : 至[java.lang.String], LABEL0_C_C_C_C_C : 上传日期[java.lang.String], LABEL0_C_C_C_C_C_C : 结案日期[java.lang.String], LABEL0_C_C_C_C_C_C_C : 至[java.lang.String], OP : fr_dialog[java.lang.String], REPORTLET : 治超案件上传统计表.cpt[java.lang.String], REPORTNAME : 治超案件上传统计表.cpt[java.lang.String], SESSIONID : 9286[java.lang.String]}][Type : page] : no function found: f
    2021-05-21 15:29
  • sw0414 sw0414(提问者) 为啥还报错
    2021-05-21 15:29
发布于2021-5-21 15:17
这个错了,是这个格式
${if(len(dateStart_c_c)=0,"","AND DATE_FORMAT(sp.createTime,'%Y-%m-%d') >="+dateStart_c_c+"'")}
张洪威Lv6高级互助
发布于2021-5-21 15:45
f(x)写方程吗。
  • 502浏览人数
  • 最后回答于:2021-5-21 15:45
