${if()}使用
${if(e==0,
select
t3.office_name,
t1.total_spec_gene_rate `今年`,
t2.total_spec_gene_rate `去年`,
t1.freight_yoy `同比`
from
select distinct office_code,office_name from freight_sales_amount_rate_analyze_day
) t3 left join
SELECT data_day,office_name,office_code,
ifnull(total_spec_gene_rate,0) total_spec_gene_rate,
ifnull(freight_yoy,0)-1 as `freight_yoy`
FROM `freight_sales_amount_rate_analyze_day`
where
"+if(len(a)=0,'1=1',' distribution_center_name  = '+a+'')+"
and  data_day =   '"+b+"'
group by office_name,office_code
) t1 on t1.office_code=t3.office_code left join
where
and  data_day = date_sub('"+b+"' ,interval 1 year)
) t2 on t2.office_code=t3.office_code
在${if()}
里面怎么使用if函数
现在这么写报错
pengfuqiang96 发布于 2021-6-1 11:53 (编辑于 2021-6-1 14:41)
发布于2021-6-1 12:26(编辑于 2021-6-1 14:51)
修改答案
${if(e==0,"select t3.office_name,t1.total_spec_gene_rate `今年`,t2.total_spec_gene_rate `去年`,t1.freight_yoy `同比`  from  (select distinct office_code,office_name from freight_sales_amount_rate_analyze_day) t3 left join
(SELECT data_day,office_name,office_code,ifnull(total_spec_gene_rate,0) total_spec_gene_rate,ifnull(freight_yoy,0)-1 as `freight_yoy`  FROM  `freight_sales_amount_rate_analyze_day`  where "+if(len(a)=0,"1=1"," distribution_center_name  = '"+a+"'")+" and  data_day = '"+b+"'  group by office_name,office_code) t1 on t1.office_code=t3.office_code left join
(SELECT data_day,office_name,office_code,ifnull(total_spec_gene_rate,0) total_spec_gene_rate FROM  `freight_sales_amount_rate_analyze_day`  where "+if(len(a)=0,"1=1"," distribution_center_name  = '"+a+"'")+" and  data_day = date_sub('"+b+"' ,interval 1 year) group by office_name,office_code) t2 on t2.office_code=t3.office_code","")}
  • pengfuqiang96 pengfuqiang96(提问者) 也不对
    2021-06-01 14:30
  • snrtuemc snrtuemc 回复 pengfuqiang96(提问者) 你仔细检查,你的几个凭借参数,不要加单引号的加,要加的不加,第一个参数b那边就有问题了,还有,if不能在引号里面,sql中没有if函数,if是帆软自己函数,你的语句问题多的很, 可以的话,你把sql贴出来,给你修改后,你在几拷贝在试试
    2021-06-01 14:35
  • pengfuqiang96 pengfuqiang96(提问者) sql 贴出来了
    2021-06-01 14:42
  • snrtuemc snrtuemc 回复 pengfuqiang96(提问者) 看下修改答案
    2021-06-01 14:50
  • pengfuqiang96 pengfuqiang96(提问者) 对了 SQL可以运行了。
    2021-06-01 15:02
发布于2021-6-1 11:59
看你的逻辑应该是当e=0时才执行语句,还到不如将这个判断放WHERE 后面 IF(e=0,"AND 1=1","and 1<>1")
圣体叶小凡Lv6高级互助
发布于2021-6-1 14:31
IF(a=1,
"select
a.id,
a.name
from table a
where 1=1
"+if(len(a)=0,'','and distribution_center_name like = '+a+'')+"
and data_day ='"+b+"'
自己拿过去按照这个格式改一改吧
  • pengfuqiang96 pengfuqiang96(提问者) 不得行 ,改完后 带入的参数a 被看作了一个列名。unknown column
    2021-06-01 14:40
shirokoLv6资深互助
发布于2021-6-1 14:55(编辑于 2021-6-1 14:56)
 ${if(e==0,
select
t3.office_name,
t1.freight_yoy `同比`
from
) t3 left join
where
"+if(len(a)=0,'1=1'," distribution_center_name  = '"+a+"'")+"
where
跟if怎么用没关系,就是引号没对上,要注意字符串拼接后还需要留下单引号给sql用
  • 1271浏览人数
  • 最后回答于:2021-6-1 14:56
