程序数据集问题
获取城市接口的数据
在idea 上正常运行  finereport上导入相关的包后能编译成功,但就是获取不到数据。
package com.fr;
import com.fr.data.AbstractTableData;
import com.yang.api.weather.cityApi.CityApi;
import com.yang.model.weather.city.City;
import com.yang.model.weather.city.CityResult;
import java.lang.reflect.Field;
import java.lang.reflect.Method;
import java.util.Arrays;
 * @Auther: zongsenyang
 * @Date: 2021/5/11 - 9:41
 * @description: com.demo.model.city
 * @version: 1.0
public class cityTest extends AbstractTableData {
    public static void main(String[] args) {
        new cityTest();
     * 定义程序数据集的列名以及数据保存的位置
    private String[] columnNames;
    private Object[][] rowData;
    public cityTest(){
        String[] fieldNames=getFieldNames(new City());
        String[] columnNames=new String[fieldNames.length];
        for (int i=0;i<columnNames.length;i++){
            columnNames[i]=fieldNames[i];
        City[] cities=getCities();
        Object[][] datas=new Object[cities.length][columnNames.length];
        for (int i=0;i<datas.length;i++){
            for (int j=0;j<datas[i].length;j++){
                datas[i][j]=getFieldValueByName(columnNames[j],cities[i]);
        this.columnNames=columnNames;
        this.rowData=datas;
        System.out.println(Arrays.toString(this.columnNames));
        for(int a=0;a<10;a++){
            System.out.println("------------------------");
            for(int b=0;b<rowData[a].length;b++) {
                System.out.println(rowData[a][b]);
     *获取返回的数据
    private City[] getCities(){
        CityResult cr=new CityApi().getCityResult();
        return cr.getResult();
     *获取对象属性名
    private static  String[] getFieldNames(Object obj){
        Field[] fields=obj.getClass().getDeclaredFields();
        String[] fieldNames=new String[fields.length];
        for(int i=0;i<fields.length;i++){
            //System.out.println(fields[i].getName());
            fieldNames[i]=fields[i].getName();
        return fieldNames;
     * 根据属性名获取数据
    private static Object getFieldValueByName(String fieldName, Object o) {
        try {
            String firstLetter = fieldName.substring(0, 1).toUpperCase();
            String getter = "get" + firstLetter + fieldName.substring(1);
            Method method = o.getClass().getMethod(getter, new Class[] {});
            Object value = method.invoke(o, new Object[] {});
            return value;
        } catch (Exception e) {
            return null;
    public int getColumnCount()  { return columnNames.length; }
    public String getColumnName(int columnIndex)  { return columnNames[columnIndex]; }
    public int getRowCount() { return rowData.length; }
    public Object getValueAt(int rowIndex, int columnIndex) { return rowData[rowIndex][columnIndex]; }
上面是Linux 上的
在自己的电脑是可以获取到数据的
FineReport 啊嘞嘞 发布于 2021-6-3 15:57 (编辑于 2021-6-3 16:03)
烟尘Lv6高级互助
发布于2021-6-3 16:14
本地能获取到,网页预览报表有值,放到服务器上就报错?
检查一下服务器jar包是否引入,class文件的package路径是否正确?tomcat要重启的。
  • 啊嘞嘞 啊嘞嘞(提问者) tomcat 需要重启吗?没重启过。。。
    2021-06-03 16:40
  • 烟尘 烟尘 回复 啊嘞嘞(提问者) 对于修改jar包或者class之类的底层文件,需要重启,模版不需要
    2021-06-03 16:45
  • 348浏览人数
  • 最后回答于:2021-6-3 16:14
