请问用一个sql查询去年本月同期
select to_char(CREDATE,'mm') CREDATE,to_char(CREDATE,'yyyy-mm') yearn,to_char(CREDATE,'yyyy') yearns,nvl(sum(inqty),0)inqty,nvl(sum(OUTQTY),0) OUTQTY
  from BMS_ST_IO_UNION_V
group by to_char(CREDATE,'mm'),to_char(CREDATE,'yyyy'),to_char(CREDATE,'yyyy-mm')  order by CREDATE,inqty,OUTQTY,yearn
ZAW 发布于 2021-6-4 09:47
悬赏:6 F币 + 添加悬赏
liu.yangLv2初级互助
发布于2021-6-4 09:55(编辑于 2021-6-4 10:40)
select   sum(case when to_char(CREDATE,'yyyy')=to_char(add_months(sysdate,-12),'yyyy') then inqty else 0 end) as "去年inqty", sum(case when to_char(CREDATE,'yyyy')=to_char(add_months(sysdate,-12),'yyyy') then OUTQTY else 0 end) as "去年OUTQTY", sum(case when to_char(CREDATE,'yyyymm')=to_char(sysdate,'yyyymm') then inqty else 0 end) as "本月inqty", sum(case when to_char(CREDATE,'yyyymm')=to_char(sysdate,'yyyymm') then OUTQTY else 0 end) as "本月OUTQTY", sum(case when to_char(CREDATE,'yyyymm')=to_char(add_months(sysdate,-12),'yyyymm') then inqty else 0 end) as "同期inqty", sum(case when to_char(CREDATE,'yyyymm')=to_char(add_months(sysdate,-12),'yyyymm') then OUTQTY else 0 end) as "同期OUTQTY"from BMS_ST_IO_UNION_V
  • ZAW ZAW(提问者) 这个${time}可以不传吗
    2021-06-04 10:01
  • liu.yang liu.yang 回复 ZAW(提问者) 可以啊 这个就是参数 你可以写固定日期都行
    2021-06-04 10:02
  • ZAW ZAW(提问者) 回复 liu.yang 那我这个不写 ${time} 替换那个字段 是CREDATE这个嘛
    2021-06-04 10:04
  • liu.yang liu.yang 回复 ZAW(提问者) CREDAT 是你表的日期字段把, ${time} 是你想查询那一天的数据 可以是那个月的任意一天,比如 20210604
    2021-06-04 10:06
  • liu.yang liu.yang 回复 ZAW(提问者) ${time} 是你想查询的日期,可以用日期控件 传参的
    2021-06-04 10:07
发布于2021-6-4 09:52
https://blog.csdn.net/weixin_41287692/article/details/80577828
  • ZAW ZAW(提问者) 可以写一下不
    2021-06-04 09:53
  • Z4u3z1 Z4u3z1 回复 ZAW(提问者) oracle不熟悉 大致应该是 SELECT A.*,lag(A.inqty, 1, null) over (order by A.CREDATE ASC,A.yearns DESC) as 去年同期 FROM ( select to_char(CREDATE,\'mm\') CREDATE,to_char(CREDATE,\'yyyy-mm\') yearn,to_char(CREDATE,\'yyyy\') yearns,nvl(sum(inqty),0)inqty,nvl(sum(OUTQTY),0) OUTQTY from BMS_ST_IO_UNION_V group by to_char(CREDATE,\'mm\'),to_char(CREDATE,\'yyyy\'),to_char(CREDATE,\'yyyy-mm\') ) A
    2021-06-04 09:59
  • ZAW ZAW(提问者) 回复 Z4u3z1 为啥第一条数据是空的 其实是有数据的
    2021-06-04 10:08
  • Z4u3z1 Z4u3z1 回复 ZAW(提问者) 不熟悉ORACLE 也没办法测试,爱莫能助 lag(A.inqty, 1, null)改成lag(A.inqty, -1, null)或者over (order by A.CREDATE ASC,A.yearns DESC) 的顺序你重新排一下
    2021-06-04 10:12
  • ZAW ZAW(提问者) 回复 Z4u3z1 你好像查询是明年的不是去年的
    2021-06-04 10:12
  • 426浏览人数
  • 最后回答于:2021-6-4 10:40
