sql求同比
select
        to_char(t.CREDATE,'mm') as CREDATE,
  t.ENTRYID,
  t2.ENTRYID,
  t2.ENTRYID,
        nvl(t1.TOTAL,0) as "同期TOTAL",--同期
        nvl(t1.SETTLEQTY,0) as "同期SETTLEQTY",--同期
        nvl(t2.TOTAL ,0)as "去年TOTAL",--去年
        nvl(t2.SETTLEQTY,0) as "去年SETTLEQTY",--去年
        to_char(t.CREDATE,'yyyy-mm') as YEARN,
        to_char(t.CREDATE,'yyyy') as YEAR,
        nvl(sum(t.TOTAL),0) as TOTAL,--当月
        nvl(sum(t.SETTLEQTY),0) as SETTLEQTY--当月
from BMS_SA_DTLQRY_V t
left join (
select  ENTRYID,
        to_char(CREDATE,'yyyymm') as year_mon,
        sum(TOTAL) as TOTAL,
        sum(SETTLEQTY) as SETTLEQTY
group by to_char(CREDATE,'yyyymm'),ENTRYID
)t1
        on to_char(add_months(t.CREDATE,-12),'yyyymm')=t1.year_mon
left join (
        select ENTRYID,
                to_char(CREDATE,'yyyy') as yearn,
group by to_char(CREDATE,'yyyy'),ENTRYID
)t2
     on  to_char(add_months(t.CREDATE,-12),'yyyy')=t2.yearn
(select DECODE(sum(t.TOTAL), 0,SUM(t2.TOTAL),0, ()) from BMS_SA_DTLQRY_V )
group by to_char(CREDATE,'mm'),
        to_char(t.CREDATE,'yyyy-mm'),
        t1.TOTAL,
t.ENTRYID,
        t1.SETTLEQTY,
        t2.TOTAL,
        t2.SETTLEQTY,
t2.ENTRYID,
  t2.ENTRYID
ZAW 发布于 2021-6-4 16:24
悬赏:6 F币 + 添加悬赏
liu.yangLv2初级互助
发布于2021-6-4 16:32(编辑于 2021-6-4 16:41)
select        to_char(t.CREDATE,'mm') as CREDATE,                          t.ENTRYID,    case when nvl(t1.TOTAL,0)=0 then 0 else nvl(sum(t.TOTAL),0)/nvl(t1.TOTAL,0) end as "同比TOTAL",--同比    case when nvl(t1.SETTLEQTY,0)=0 then 0 else nvl(sum(t.SETTLEQTY),0)/nvl(t1.SETTLEQTY,0) end as "同比SETTLEQTY",--同比        nvl(t1.TOTAL,0) as "同期TOTAL",--同期        nvl(t1.SETTLEQTY,0) as "同期SETTLEQTY",--同期        nvl(t2.TOTAL ,0)as "去年TOTAL",--去年        nvl(t2.SETTLEQTY,0) as "去年SETTLEQTY",--去年        to_char(t.CREDATE,'yyyy-mm') as YEARN,        to_char(t.CREDATE,'yyyy') as YEAR,        nvl(sum(t.TOTAL),0) as TOTAL,--当月        nvl(sum(t.SETTLEQTY),0) as SETTLEQTY--当月from BMS_SA_DTLQRY_V tleft join (select  ENTRYID,        to_char(CREDATE,'yyyymm') as year_mon,        sum(TOTAL) as TOTAL,        sum(SETTLEQTY) as SETTLEQTYfrom BMS_SA_DTLQRY_Vgroup by to_char(CREDATE,'yyyymm'),ENTRYID)t1        on to_char(add_months(t.CREDATE,-12),'yyyymm')=t1.year_mon and t.ENTRYID=t1.ENTRYIDleft join (        select ENTRYID,                to_char(CREDATE,'yyyy') as yearn,                sum(TOTAL) as TOTAL,                sum(SETTLEQTY) as SETTLEQTYfrom BMS_SA_DTLQRY_Vgroup by to_char(CREDATE,'yyyy'),ENTRYID)t2     on  to_char(add_months(t.CREDATE,-12),'yyyy')=t2.yearn and t.ENTRYID=t2.ENTRYIDgroup by to_char(CREDATE,'mm'),        to_char(t.CREDATE,'yyyy-mm'),        to_char(CREDATE,'yyyy'),        t1.TOTAL,                                t.ENTRYID,        t1.SETTLEQTY,        t2.TOTAL,        t2.SETTLEQTY
  • 387浏览人数
  • 最后回答于:2021-6-4 16:41
