大佬们这是什么问题java.net.SocketException:Connectionres
警告: /com/fr/fs/resources/images/mobile/cover/v.png
ClientAbortException:  java.net.SocketException: Connection reset by peer: socket write error
at org.apache.catalina.connector.OutputBuffer.realWriteBytes(OutputBuffer.java:373)
at org.apache.tomcat.util.buf.ByteChunk.flushBuffer(ByteChunk.java:437)
at org.apache.catalina.connector.OutputBuffer.doFlush(OutputBuffer.java:321)
at org.apache.catalina.connector.OutputBuffer.flush(OutputBuffer.java:299)
at org.apache.catalina.connector.CoyoteOutputStream.flush(CoyoteOutputStream.java:103)
at com.fr.web.core.A.lD.process(Unknown Source)
at com.fr.stable.fun.impl.NoSessionIDOPService.process(Unknown Source)
at com.fr.web.core.ReportDispatcher.dealWithOp(Unknown Source)
at com.fr.web.core.ReportDispatcher.dealWeblet(Unknown Source)
at com.fr.web.core.ReportDispatcher.dealWithRequest(Unknown Source)
at com.fr.web.BaseServlet.doGet(Unknown Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:629)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:304)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:240)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:164)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:462)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:164)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:100)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:563)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:403)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:301)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:162)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:140)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:309)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.net.SocketException: Connection reset by peer: socket write error
at java.net.SocketOutputStream.socketWrite0(Native Method)
at java.net.SocketOutputStream.socketWrite(Unknown Source)
at java.net.SocketOutputStream.write(Unknown Source)
at org.apache.coyote.http11.InternalOutputBuffer.realWriteBytes(InternalOutputBuffer.java:218)
at org.apache.tomcat.util.buf.ByteChunk.append(ByteChunk.java:351)
at org.apache.coyote.http11.InternalOutputBuffer$OutputStreamOutputBuffer.doWrite(InternalOutputBuffer.java:243)
at org.apache.coyote.http11.filters.ChunkedOutputFilter.doWrite(ChunkedOutputFilter.java:117)
at org.apache.coyote.http11.AbstractOutputBuffer.doWrite(AbstractOutputBuffer.java:190)
at org.apache.coyote.Response.doWrite(Response.java:533)
at org.apache.catalina.connector.OutputBuffer.realWriteBytes(OutputBuffer.java:368)
... 29 more
FineReport AoLiQi 发布于 2021-7-2 20:56
发布于2021-7-2 22:14
错误显示:「连接被重置了」;-- 检查下数据连接是否正常,刷新下页面!-- 连接池可能达到了最大连接数,空闲连接被释放断开了等!
  • AoLiQi AoLiQi(提问者) 大佬,参考下这个问题哈,两个一起的 会是什么原因呢 https://bbs.fanruan.com/wenda/question/78524.html
    2021-07-03 09:54
  • zsh331 zsh331 回复 AoLiQi(提问者) 这二个问题从报错信息上看没有直接关系,此贴-反馈的信息就是连接重置了,引起连接重置的因素很多,上面我也列举了一些,如果可以的话,建议再重启下服务;另外由于你是8.0版本,没有对应的测试环境,建议咨询技术支持;+++++++++++++可以通过添加QQ:800049425 拨打电话:4008118890 都可以联系到我们的技术支持 技术支持的工作时间为:工作日 9:00-12:00 、13:30-17:30
    2021-07-03 10:59
  • AoLiQi AoLiQi(提问者) 回复 zsh331 警告: /com/fr/fs/resources/images/mobile/cover/v.png 大佬,之前应该没有这种类型的告警,我想会不会是丢失了类似于控件的样式文件(背景图片)之类的 或者大佬知道控件的样式文件(背景图片)存放在哪么,我去替换下文件看看
    2021-07-03 11:21
  • zsh331 zsh331 回复 AoLiQi(提问者) 这个文件应该是在系统jar里面,目前我也没有8.0版本的jar文件,你可以参考这个文档解压jar找找;https://help.finereport.com/finereport8.0/doc-view-1163.html
    2021-07-03 14:06
  • AoLiQi AoLiQi(提问者) 回复 zsh331 好嘞感谢感谢
    2021-07-03 22:27
发布于2021-7-3 08:54
    2021-07-03 09:54
  • 455浏览人数
  • 最后回答于:2021-7-3 08:54
