Finebi从5.1.9升级到5.1.14后,启动报错
报错信息如下:
2021-07-14 10:19:50,246 FinePluginController-6-worker-1 ERROR [system] http://localhost:12100/connect/checkPid connect failed
2021-07-14 10:19:50,263 FinePluginController-6-worker-1 ERROR [system] [jstack, 15080] call failed
2021-07-14 10:19:50,264 FinePluginController-6-worker-1 ERROR [system] Cannot run program "jstack": CreateProcess error=2, 系统找不到指定的文件。
java.io.IOException: Cannot run program "jstack": CreateProcess error=2, 系统找不到指定的文件。
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at java.lang.Runtime.exec(Runtime.java:620)
at java.lang.Runtime.exec(Runtime.java:485)
at com.fr.plugin.operation.service.SystemCMDService.execute(Unknown Source)
at com.fr.plugin.operation.service.ProcessService.hasJavaEnv(Unknown Source)
at com.fr.plugin.operation.client.core.ServerStarter.start(Unknown Source)
at com.fr.plugin.operation.client.core.ClientOrganization.start(Unknown Source)
at com.fr.plugin.operation.core.OrganizationGroup.start(Unknown Source)
at com.fr.plugin.operation.client.FineOperationLifecycle.afterRun(Unknown Source)
at com.fr.plugin.A.F.A$1.on(Unknown Source)
at com.fr.plugin.observer.PluginEventListener.on(Unknown Source)
at com.fr.event.EventDispatcher.fire(Unknown Source)
at com.fr.plugin.observer.PluginEventTrigger.fire(Unknown Source)
at com.fr.plugin.A.S.D.A(Unknown Source)
at com.fr.plugin.A.S.D.W(Unknown Source)
at com.fr.plugin.A.S.H.C(Unknown Source)
at com.fr.plugin.A.S.H.x(Unknown Source)
at com.fr.plugin.A.S.H.W(Unknown Source)
at com.fr.plugin.A.N.B.E(Unknown Source)
at com.fr.plugin.A.N.B.g(Unknown Source)
at com.fr.plugin.A.N.B.B(Unknown Source)
at com.fr.plugin.A.N.B$2.A(Unknown Source)
at com.fr.plugin.A.N.B$2.call(Unknown Source)
at com.fr.plugin.A.N.B$3.call(Unknown Source)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.io.IOException: CreateProcess error=2, 系统找不到指定的文件。
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl.<init>(ProcessImpl.java:386)
at java.lang.ProcessImpl.start(ProcessImpl.java:137)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
... 31 common frames omitted
2021-07-14 10:19:56,290 FinePluginController-6-worker-1 ERROR [system] http://localhost:12100/connect/stop connect failed
2021-07-14 10:20:20,010 FinePluginController-6-worker-1 ERROR [system] http://localhost:12100/connect/checkPid connect failed
2021-07-14 10:20:20,026 FinePluginController-6-worker-1 ERROR [system] [jstack, 15080] call failed
2021-07-14 10:20:20,026 FinePluginController-6-worker-1 ERROR [system] Cannot run program "jstack": CreateProcess error=2, 系统找不到指定的文件。
FineBI 用户B4Y3p9853 发布于 2021-7-14 11:45
发布于2022-1-14 22:15
5.1.5后的版本升级指南-https://help.fanruan.com/finebi/doc-view-1487.html
  • 284浏览人数
  • 最后回答于:2022-1-14 22:15
