select
  dt.label,
  aa.old_activity_date ,
  aa.activity_date ,
  case when cc.rate is  null then    aa.eqp_name
       else  concat(concat(aa.eqp_name ,'   利用率:'),concat(decode(substr(cc.rate,1,1),'.','0'||cc.rate,cc.rate),'%'))
  end as eqpName
  from
    sys_dict dt
  left join
            select ss.ID,
            ss.eqp_code,
            ss.eqp_name,
            ss.States,
            case when '${start_date}' is null then ss.old_activity_date
                 when ss.old_activity_date < to_date('${start_date}', 'yyyy-mm-dd hh24:mi:ss') then to_date('${start_date}', 'yyyy-mm-dd hh24:mi:ss')
                 else ss.old_activity_date
            end as old_activity_date,
            case when '${end_date}' is null then ss.activity_date
                 when ss.activity_date < to_date('${end_date}', 'yyyy-mm-dd hh24:mi:ss')  then ss.activity_date
                 else to_date('${end_date}', 'yyyy-mm-dd hh24:mi:ss')
            end as activity_date
            from (
            SELECT T.ID,
            eq.eqp_code,
            eq.eqp_name,
            t.old_state as States,
            t.old_activity_date,
            t.activity_date
            FROM mp_eqp_activity t
            left join mc_eqp_eqpver eq on eq.equipment_id = t.eqp_id and eq.del_flag='0'
            where t.old_state is not null
              and t.activity_date is not null
              and t.eqp_activity='AdjustState'
              and t.old_activity_date is not null
              and (t.eqp_name like '%${eqp_name}%' or '${eqp_name}' is null)
              and (('${start_date}' is null and '${end_date}' is null) or
                   ('${start_date}' is null and t.activity_date < to_date('${end_date}', 'yyyy-mm-dd hh24:mi:ss')  ) or
                   (t.activity_date >= to_date('${start_date}', 'yyyy-mm-dd hh24:mi:ss') and '${end_date}' is null ) or
                   (t.old_activity_date >=  to_date('${start_date}', 'yyyy-mm-dd hh24:mi:ss') and t.old_activity_date < to_date('${end_date}', 'yyyy-mm-dd hh24:mi:ss') ) or
                   (t.activity_date >=  to_date('${start_date}', 'yyyy-mm-dd hh24:mi:ss') and t.activity_date < to_date('${end_date}', 'yyyy-mm-dd hh24:mi:ss')  )
            union all
            select c.ID,
              c.eqp_code,
              c.eqp_name,
              case when '${end_date}' is null then c.NEW_STATE
                   when c.activity_date >= to_date('${end_date}', 'yyyy-mm-dd hh24:mi:ss')  then c.OLD_STATE
                   else c.NEW_STATE
              end as status,
              case when '${end_date}' is null then c.activity_date
                   when c.activity_date >= to_date('${end_date}', 'yyyy-mm-dd hh24:mi:ss')  then c.old_activity_date
                   else c.activity_date
              case when '${end_date}' is null then sysdate
                   when c.activity_date >= to_date('${end_date}', 'yyyy-mm-dd hh24:mi:ss')  then c.activity_date
                   else SYSDATE
              from
              (SELECT T.ID,
                eq.eqp_code,
                eq.eqp_name,
                t.old_state,
                t.new_state,
                t.activity_date,
                row_number() over(partition by t.eqp_id order by t.activity_date desc) rn
              ) c
              where c.rn = 1
              and ('${end_date}' is null or c.activity_date < to_date('${end_date}', 'yyyy-mm-dd hh24:mi:ss') )
            ) ss
        )aa
  on
    dt.VALUE =aa.states
    left join (   select pp.eqp_code,round(sum((TO_DATE(to_char(pp.activity_date,'yyyy-mm-dd hh24:mi:ss'),'yyyy-mm-dd hh24:mi:ss')- TO_DATE(to_char(pp.old_activity_date,'yyyy-mm-dd hh24:mi:ss'),'yyyy-mm-dd hh24:mi:ss')))
/(to_date('${end_date}', 'yyyy-mm-dd hh24:mi:ss')-to_date('${start_date}', 'yyyy-mm-dd hh24:mi:ss')+1)*100,2) as rate
     from (select ss.ID,
            ss.eqp_code,
            ss.eqp_name,
            ss.States,
            from (
            SELECT T.ID,
            eq.eqp_code,
            eq.eqp_name,
            t.activity_date
              and t.eqp_activity='AdjustState'--  and t.old_state='InWork'
            union all
            select c.ID,
              c.eqp_code,
              c.eqp_name,
                   else c.NEW_STATE
              end as status,
                   else SYSDATE
              from
              (SELECT T.ID,
                eq.eqp_code,
                eq.eqp_name,
                t.old_state,
                t.new_state,
                t.activity_date,
                  and t.eqp_activity='AdjustState'  --and t.old_state='InWork'
              ) c
              where c.rn = 1
            ) ss)pp where pp.States='InWork' group by pp.eqp_code)cc
                   on aa.eqp_code = cc.eqp_code
  where
    dt.type='MC_EQP_EQUIPMENT.EQP_STATE'
  order by aa.eqp_code, aa.eqp_name, aa.activity_date,decode(dt.label,'设备待料',1,'正常生产',2,'计划停机',3,'故障维修',4,'故障停机',5,'设备扣留',6,'设备调试',7)
FineReport iwongf2041 发布于 2021-7-20 09:05
iwongf2041Lv3见习互助
发布于2021-7-21 14:42
+1去掉了!!!
  • 0关注人数
  • 261浏览人数
  • 最后回答于:2021-7-21 14:42
