关于finedbfine_authority_object表问题
已知 图里的角色有管理报表目录下的所有报表权限,fine_authority_object表里为什么只会存一条记录。如果我查出其所有的报表该怎么做
select distinct a.username,a.realname,b.roleid,c.name ,e.parentid,e.displayname,e.path
from  fine_user a
left join fine_user_role_middle b
ON a.id = b.userid
left join FINE_CUSTOM_ROLE c
on c.id = b.roleid
left join fine_authority  d
ON d.roleid = b.roleid
left join FINE_AUTHORITY_OBJECT  e
on e.id = d.authorityentityid
where realname = 'XX'
FineReport Mors 发布于 2021-7-22 15:00 (编辑于 2021-7-22 15:04)
ycswyw1123Lv6初级互助
发布于2021-7-22 15:08(编辑于 2021-7-22 15:09)
WITH TB AS (
SELECT
obj.ID,
obj.DISPLAYNAME,
obj.PARENTID,
obj.SORTINDEX
FROM
FINE_AUTHORITY_OBJECT obj
CONNECT BY PRIOR obj.PARENTID = obj.ID
START WITH EXISTS (SELECT 1 FROM (SELECT AUTHORITYENTITYID FROM FINE_AUTHORITY WHERE EXISTS (SELECT 1 FROM (SELECT ID FROM FINE_CUSTOM_ROLE WHERE NAME ='${rolename}') A WHERE A.ID=FINE_AUTHORITY.ROLEID) AND AUTHORITY=2) A WHERE A.AUTHORITYENTITYID=obj.ID )
UNION ALL
SELECT
obj.ID,
obj.DISPLAYNAME,
obj.PARENTID,
obj.SORTINDEX
FROM
CONNECT BY PRIOR obj.ID = obj.PARENTID
SELECT DISTINCT * FROM TB WHERE ID <> 'decision-directory-root' AND ID <> 'decision-homepage-root' ORDER BY SORTINDEX
  • Mors Mors(提问者) 这是oracle的吗
    2021-07-22 15:15
  • ycswyw1123 ycswyw1123 回复 Mors(提问者) 是的
    2021-07-22 15:29
  • Mors Mors(提问者) 回复 ycswyw1123 finedb不是hsql吗
    2021-07-22 15:41
  • ycswyw1123 ycswyw1123 回复 Mors(提问者) 我这边用的外置数据库,表都迁到oracle数据库了
    2021-07-22 15:44
luojian0323Lv7资深互助
发布于2021-7-22 15:03
sql放上来。你这个明显是多表关联查询的结果,
  • Mors Mors(提问者) 已放上
    2021-07-22 15:04
  • Mors Mors(提问者) select distinct a.username,a.realname,b.roleid,c.name ,e.parentid,e.displayname,e.path from fine_user a left join fine_user_role_middle b ON a.id = b.userid left join FINE_CUSTOM_ROLE c on c.id = b.roleid left join fine_authority d ON d.roleid = b.roleid left join FINE_AUTHORITY_OBJECT e on e.id = d.authorityentityid where realname = \'XX\'
    2021-07-22 15:07
杨朝健Lv5中级互助
发布于2021-7-22 15:26(编辑于 2021-7-22 15:43)
取fine_authority d on d.roleid = b.roleid
and authorityEntityType = 0 -- 目录权限
and authority = 2 -- 允许
and authoritytype= 1 -- 查看
这个AUTHORITYENTITYID分2种,报表和目录
1.报表 和FINE_AUTHORITY_OBJECT的ID关联取到报表信息
2.目录 和FINE_AUTHORITY_OBJECT的parentid关联,取到的结果也分报表和目录
2.1 报表
EXPANDTYPE=102为报表
2.2 目录
EXPANDTYPE=3为目录,ID为目录ID,重复2步骤
还要减去 目录授权了,但是目录下的某模板或目录没授权的
减去的模板或目录如下,可在2步骤时做判断过滤
and authority = 1 -- 拒绝
  • 529浏览人数
  • 最后回答于:2021-7-22 15:43
