分组请问怎么相加
SELECT nvl(sum(t.QUANTITY),0) as QUANTITY,t.INSPSTATUSNAME,nvl(t1.QUANTITYt,0),t.INSPSTATUS,
TO_CHAR(to_date(t.FDATE,'yyyy-mm-dd'),'yyyy-mm') as tdata,
 case t.INSPSTATUS when 'Unqualified' then '2'
                   when 'Qualified' then '1'
when 'Waiting' then '3'
                            else '4'
          end as status,
TO_CHAR(to_date(t.FDATE,'yyyy-mm-dd'),'mm') as month,
TO_CHAR(to_date(t.FDATE,'yyyy-mm-dd'),'yyyy') as year,
SYSDATE,
nvl(t2.folt,0) as folt,nvl(t3.countfolt,0) as countfolt
FROM WMS_STORAGELIST t
LEFT JOIN (
select
 TO_CHAR(to_date(FDATE,'yyyy-mm-dd'),'yyyy-mm') as year_mon,
 sum(QUANTITY) as QUANTITYt,INSPSTATUSNAME
GROUP BY
TO_CHAR(to_date(FDATE,'yyyy-mm-dd'),'yyyy-mm'),INSPSTATUSNAME
)t1 on t1.INSPSTATUSNAME=t.INSPSTATUSNAME and to_char(add_months(to_date(t.FDATE,'yyyy-mm-dd'),-12),'yyyy-mm')=t1.year_mon
LEFT JOIN (
select COUNT(DISTINCT FACTORYLOTNO || WORKLOTNO) as folt,INSPSTATUSNAME,TO_CHAR(to_date(FDATE,'yyyy-mm-dd'),'yyyy-mm') as year_mon2 from WMS_STORAGELIST GROUP BY INSPSTATUSNAME,TO_CHAR(to_date(FDATE,'yyyy-mm-dd'),'yyyy-mm')
) t2
on t2.INSPSTATUSNAME=t.INSPSTATUSNAME and TO_CHAR(to_date(t.FDATE,'yyyy-mm-dd'),'yyyy-mm')=t2.year_mon2
LEFT JOIN (
select COUNT(DISTINCT FACTORYLOTNO || WORKLOTNO) as countfolt,INSPSTATUSNAME,TO_CHAR(to_date(FDATE,'yyyy-mm-dd'),'yyyy-mm') as year_mon2 from WMS_STORAGELIST GROUP BY INSPSTATUSNAME,TO_CHAR(to_date(FDATE,'yyyy-mm-dd'),'yyyy-mm')
) t3
on t3.INSPSTATUSNAME=t.INSPSTATUSNAME and to_char(add_months(to_date(t.FDATE,'yyyy-mm-dd'),-12),'yyyy-mm')=t3.year_mon2
where
t.FDATE>='2021'
GROUP BY t.INSPSTATUSNAME,TO_CHAR(to_date(t.FDATE,'yyyy-mm-dd'),'yyyy-mm'),TO_CHAR(to_date(t.FDATE,'yyyy-mm-dd'),'mm'),
TO_CHAR(to_date(t.FDATE,'yyyy-mm-dd'),'yyyy') ,t1.QUANTITYt,t.INSPSTATUS,t2.folt,t3.countfolt
ORDER BY TO_CHAR(to_date(t.FDATE,'yyyy-mm-dd'),'yyyy-mm')
ZAW 发布于 2021-7-22 16:30
liu.yangLv2初级互助
发布于2021-7-22 16:41(编辑于 2021-7-22 17:01)
按照图片得要求,INSPSTATUSNAME,INSPSTATUS 这两个字段都需要处理下,
都需要  case when INSPSTATUSNAME in('合格','试用') then '新值' else INSPSTATUSNAME end,
case when INSPSTATUS in('Qualified','Probational') then '新值' else INSPSTATUS end
huahua3211Lv3见习互助
发布于2021-7-22 16:48
case when INSPSTATUSNAME in ('合格','试用') then  '合格' end ,把这个字段处理一下
zjc@Lv3初级互助
发布于2021-7-22 18:32
WHERE T.FDATE >= '2021'
看到你的where条件想提醒你,
'202001011'>'2021',不知道T.FDATE字段是否只是存的年份,如果是那没问题
  • 478浏览人数
  • 最后回答于:2021-7-22 18:32
