以下报错怎么解决:数据集可以查出来,报表报错
误代码:11300001 数据集配置错误Query:java.util.concurrent.ExecutionException: com.sap.db.jdbc.exceptions.JDBCDriverException: SAP DBTech JDBC: [2048]: column store error: AttributeEngine: divide by zero;double comma(double round(double "SYSTEM.#_SYS_QO_COL_7e83534142e0:401000000093f328.COL$1$$sum$", int '0'), double [here]divide(double sqlsub(double round(double "SYSTEM.#_SYS_QO_COL_7e83534142e0:401000000093f328.COL$0$$sum$", int '0'), double "__common1"), double "__common1")),(SYSTEM.#_SYS_QO_COL_7e83534142e0:401000000093f328.COL$0$$sum$ = 1.33981e+07[double], SYSTEM.#_SYS_QO_COL_7e83534142e0:401000000093f328.COL$1$$sum$ = 0[double]); checkNull false:   at function __trex_field_Double__()
FineReport Basis 发布于 2021-8-4 20:51 (编辑于 2021-8-4 21:06)
发布于2021-8-4 21:35
单元格运算存在异常,分母有0值;
  • 353浏览人数
  • 最后回答于:2021-8-4 21:35
