frm上,日期控件只显示周一可选
参考论坛上的帖子修改了js,cpt毫无问题,frm无效果,大家有什么好办法
FineReport kaqiyu 发布于 2021-8-17 10:03
发布于2021-8-17 10:07(编辑于 2021-8-17 10:10)
测试支持鞠策报表的啊,你是不是代码复制错了
============附上只选周一代码,给控件初始化事件加js
this._createCalendar = function() {
var o = this.options;
var self = this;
if (this.options.need2BuildConfig === true && this.options.data) {
this.options.data.resetStatus(this.createDependencePara4Data());
var data = this.options.data.getData();
if (data[0].data) {
if (data[0].data.startDate) {
var sd = new Date(data[0].data.startDate);
if (!FR.isInvalidDate(sd)) {
o.startDate = FR.date2Str(sd, 'yyyy-MM-dd');
this.std = this._createStartDate(o.startDate, o.format, this.viewMode);
if (data[0].data.endDate) {
var ed = new Date(data[0].data.endDate);
if (!FR.isInvalidDate(ed)) {
o.endDate = FR.date2Str(ed, 'yyyy-MM-dd');
this.edd = this._createEndDate(o.endDate, o.format, this.viewMode);
this.options.rebuildConfig = false;
this.datepicker = new FR.DatePicker({
renderEl: this.$view,
viewMode: this.viewMode,
date: FR.str2Date(this.editComp.val(), o.format),
dateFormat: o.format,
startDate: this.std,
endDate: this.edd,
onDateUpdate: function() {
if ($(':focus').length === 0) {
self.editComp.focus();
self.editComp.val(FR.date2Str(this.getValue(), o.format));
self.isValidateInput();
self.fireEvent(FR.Events.AFTEREDIT);
this.datepicker._loadDateData = function(table, date) {
if (!date) {
return;
var year = date.getFullYear(),
month = date.getMonth(),
day = date.getDate();
var today = new Date(),
TY = today.getFullYear(),
TM = today.getMonth(),
TD = today.getDate();
this.cache.showYear = year;
this.cache.showMonth = month;
var std = this.options.startDate,
edd = this.options.endDate;
table.$title.text(Date._MN[month] + ", " + year);
var nextDay = new Date(date);
nextDay.setDate(nextDay.getMonthDays() + 1);
if ((edd && nextDay > edd) || nextDay.getFullYear() > this.CONSTS.MAXYEAR) {
table.$nextm.addClass('disabled').removeClass('hover').data('disabled', true);
} else {
table.$nextm.removeClass('disabled').data('disabled', false);
var prevDay = new Date(date);
prevDay.setDate(0);
if ((std && prevDay < std) || prevDay.getFullYear() < this.CONSTS.MINYEAR) {
table.$prevm.addClass('disabled').removeClass('hover').data('disabled', true);
} else {
table.$prevm.removeClass('disabled').data('disabled', false);
date.setDate(1);
var day1 = (date.getDay() - this.CONSTS.FIRSTDAY) % 7;
date.setDate(0 - day1);
date.setDate(date.getDate() + 1);
var $frow = table.find('tbody').children().eq(0);
for (var i = 0; i < 6; i++) {
if (!$frow.length) {
break;
var $cell = $frow.children().eq(0);
$cell.addClass('week wn').text(date.getWeekNumber());
var iday;
for (var j = 0; j < 7; ++j, date.setDate(iday + 1)) {
$cell = $cell.next();
$cell.removeClass().data('nav', this.CONSTS.NAV['day']);
if (!$cell.length) {
break;
iday = date.getDate();
$cell.text(iday);
var current_month = (date.getMonth() == month);
if (!current_month || j != 1) {
$cell.addClass('oday').data('disabled', true);
continue;
var disabled = false;
if ((std != null && std > date) || (edd != null && edd < date)) {
$cell.addClass('day disabled');
disabled = true;
} else {
$cell.addClass('day');
$cell.data('disabled', disabled);
if (!disabled) {
if (current_month && iday == day) {
this.cache.selectedDate && this.cache.selectedDate.removeClass('selected');
$cell.addClass('selected');
this.cache.selectedDate = $cell;
this.cache.showDay = iday;
if (date.getFullYear() == TY &&
date.getMonth() == TM &&
iday == TD) {
$cell.addClass('today');
var wday = date.getDay();
if ([0, 6].indexOf(wday) != -1) {
$cell.addClass("weekend");
$frow = $frow.next();
if (FR.Browser.isIE8() && this.$view.css('visibility') == 'hidden') {
this.$view.css("visibility", "visible");
} else {
this.$view.show();
$(document).bind('mousedown', this, this.collapseIf);
this.modifyPosition();
var tr = $('tbody>tr', this.datepicker.$datetable);
for (var i = 0; i < tr.length; i++) {
var $days = $('td[class!="week wn"]', tr);
for (var j = 0; j < $days.length; j++) {
var $day = $($days[j]);
if (1 != j && !$day.hasClass('oday')) {
$day.data("disabled", true);
$day.attr('class', 'oday');
  • kaqiyu kaqiyu(提问者) 好像发现问题了,url 后缀带上这个&op=form_adaptive 就不行,去掉就好了
    2021-08-17 10:39
  • kaqiyu kaqiyu(提问者) 使用新自适应插件预览都有后缀,大神你这边是退回旧版了嘛
    2021-08-17 10:43
  • snrtuemc snrtuemc 回复 kaqiyu(提问者) 新自适应插件,以前的js很多会不能用,我是没有装这个插件,你的有可能是是插件引起
    2021-08-17 10:46
  • kaqiyu kaqiyu(提问者) 回复 snrtuemc 确实是这个问题,我直接把模板退回旧版就可以了
    2021-08-17 11:03
  • Tiffany Tiffany 为什么我用你这个脚本当前月的星期一显示不了
    2022-03-29 01:26
  • 1418浏览人数
  • 最后回答于:2021-8-17 10:10
