You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '-假数据表' at line 1
kmx277564915(提问者)是:drop table [AAA-假数据表]; 命令么,我试了,还是报错:You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near \'[-假数据]\' at line 1
