mongodb链接报错????
java.util.concurrent.TimeoutException
java.util.concurrent.FutureTask.get(FutureTask.java.205)
com.fr.data.operator.DataOperator.testConnectionWithException(DataOperator.java.264)
com.fr.design.data.datapane.connect.DatabaseConnectionPane$1$1.doInBackground(null.-1)
javax.swing.SwingWorker$1.call(SwingWorker.java.295)
java.util.concurrent.FutureTask.run(FutureTask.java.266)
javax.swing.SwingWorker.run(SwingWorker.java.334)
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java.1149)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java.624)
java.lang.Thread.run(Thread.java.748)
FineReport pengfuqiang96 发布于 2021-8-26 16:46
pengfuqiang96Lv7初级互助
发布于2021-8-30 08:20
测试的IP受到限制登不上,换成正式的就登录成功了
发布于2021-8-29 22:03
MongoDB 数据库插件-https://help.fanruan.com/finereport/doc-view-1413.html
  • 358浏览人数
  • 最后回答于:2021-8-30 08:20
