tomcat报错furtheroccurrencesofHTTPheaderparsing
信息 [http-apr-8080-exec-160] org.apache.coyote.http11.AbstractHttp11Processor.process Error parsing HTTP request header Note: further occurrences of HTTP header parsing errors will be logged at DEBUG level. java.lang.IllegalArgumentException: Invalid character found in the request target. The valid characters are defined in RFC 7230 and RFC 3986    at org.apache.coyote.http11.InternalAprInputBuffer.parseRequestLine(InternalAprInputBuffer.java:239)    at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1045)    at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:684)    at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2521)    at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2510)    at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)    at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)    at java.lang.Thread.run(Thread.java:748)
FineReport 张宇 发布于 2021-9-14 14:25 (编辑于 2021-9-14 14:26)
发布于2021-9-14 14:30
  • 张宇 张宇(提问者) 不处理这个异常没啥影响吧
    2021-09-14 14:36
  • snrtuemc snrtuemc 回复 张宇(提问者) 不影响你使用,可以不处理
    2021-09-14 14:37
  • 张宇 张宇(提问者) [DEBUG] 2021-09-14 14:40:10,170 method:com.fr.third.org.quartz.core.JobRunShell. run(JobRunShell.java:201) Calling execute on job BAOBIAO\\tiaojie.cpt.报表1 [DEBUG] 2021-09-14 14:40:10,170 method:com.fr.third.org.quartz.impl.jdbcjobstore .SimpleSemaphore.obtainLock(SimpleSemaphore.java:86) Lock \'TRIGGER_ACCESS\' is desired by: QuartzScheduler_Worker-7 [DEBUG] 2021-09-14 14:40:10,170 method:com.fr.third.org.quartz.impl.jdbcjobstore .SimpleSemaphore.obtainLock(SimpleSemaphore.java:93) Lock \'TRIGGER_ACCESS\' is being obtained: QuartzScheduler_Worker-7 [DEBUG] 2021-09-14 14:40:10,170 method:com.fr.third.org.quartz.impl.jdbcjobstore .SimpleSemaphore.obtainLock(SimpleSemaphore.java:110) Lock \'TRIGGER_ACCESS\' given to: QuartzScheduler_Worker-7 Lock \'TRIGGER_ACCESS\' retuned by: QuartzScheduler_QuartzSchedulerThread 这是啥错误?
    2021-09-14 14:46
  • snrtuemc snrtuemc 回复 张宇(提问者) 不影响你工程,不用管,你日志开DEBUG会有很多无用信息的。。。
    2021-09-14 14:49
  • 张宇 张宇(提问者) 回复 snrtuemc 日志该用哪个级别?
    2021-09-14 14:51
发布于2021-9-14 14:31
    2021-09-14 14:36
  • Z4u3z1 Z4u3z1 回复 张宇(提问者) 影响使用才管它,不影响就看心情(想处理就复制一个到测试环境慢慢改)
    2021-09-14 15:07
  • 436浏览人数
  • 最后回答于:2021-9-14 14:31
