fr集合springboot原有工程代码嵌入式tomcat启动失败(搞了快两个星期了啊啊)
fr ,或springboot项目(有工程代码)单独启动可以,结合就报错
报错提示截取部分:
java.util.ServiceConfigurationError: com.sun.tools.attach.spi.AttachProvider: Provider sun.tools.attach.WindowsAttachProvider could not be instantiated(tools path环境变量添加,attch)
log4j:ERROR No output stream or file set for the appender named [null].(这个不知是不是springboot项目的错)
java.lang.ClassCastException: java.lang.ClassNotFoundException cannot be cast to [Ljava.lang.Object;
 atorg.springframework.boot.context.properties.EnableConfigurationPropertiesImportSelector$ConfigurationPropertiesBeanRegistrar.lambda$collectClasses$1(EnableConfigurationPropertiesImportSelector.java:83)
 at java.util.stream.ReferencePipeline$7$1.accept(ReferencePipeline.java:267)
at java.util.LinkedList$LLSpliterator.forEachRemaining(LinkedList.java:1235)
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:481)
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:471)
at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:708)
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
at java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:499)
1:07:05.861 [RMI TCP Connection(3)-127.0.0.1] WARN  o.s.b.SpringApplication - [log,89] -
Unable to close ApplicationContextjava.lang.IllegalStateException: Failed to introspect Class [com.sinosoft.framework.config.CaptchaConfig] from ClassLoader [ParallelWebappClassLoader  context: ROOT  delegate: false----------> Parent Classloader:java.net.URLClassLoader@4461c7e3]
 at org.springframework.util.ReflectionUtils.getDeclaredMethods(ReflectionUtils.java:659)
at org.springframework.util.ReflectionUtils.doWithMethods(ReflectionUtils.java:556)
at org.springframework.util.ReflectionUtils.doWithMethods(ReflectionUtils.java:541)
at org.springframework.util.ReflectionUtils.getUniqueDeclaredMethods(ReflectionUtils.java:599)
8-Oct-2021 11:07:05.903 涓ラ噸 [RMI TCP Connection(3)-127.0.0.1] org.apache.tomcat.util.modeler.BaseModelMBean.invoke 璋冪敤鏂规硶[manageApp]鏃跺彂鐢熷紓甯� java.lang.IllegalStateException: 鍚?姩瀛愮骇鏃跺嚭閿�  at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:729)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:698)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:696)
  at org.apache.catalina.startup.HostConfig.manageApp(HostConfig.java:1783)
 at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
 at java.lang.reflect.Method.invoke(Method.java:498)
 at org.apache.tomcat.util.modeler.BaseModelMBean.invoke(BaseModelMBean.java:293)
FineReport DMTwdonK 发布于 2021-10-8 11:25 (编辑于 2021-10-8 15:58)
发布于2022-4-2 21:47
SpringBoot 集成 FineReport-https://bbs.fanruan.com/thread-133700-1-1.html
DMTwdonKLv2见习互助
发布于2021-10-9 10:11
不行,我要劝公司不要买帆软。要从根源上解决问题。。。。。。。。。。。。。。。
  • 505浏览人数
  • 最后回答于:2022-4-2 21:47
