Finereport9.0 部署到tomcat打不开。报404
Finereport9.0 部署到tomcat打不开。报404;
tomcat 可以打开,jdk版本是1.8,tomcat是9.0
FineReport sqlichao 发布于 2019-5-24 09:15
共5回答
sqlichaoLv2见习互助
发布于2019-5-24 15:16
重装了java好了
flyingsnakeLv6资深互助
发布于2019-5-24 09:16
cmd下执行下javac
看看java环境变量是不是配置正确
firegunzxLv6高级互助
发布于2019-5-24 09:17
目录复制错了,应该是webreport
Tomcat服务器部署-http://help.finereport.com/finereport9.0/doc-view-772.html
白水先生Lv3初级互助
发布于2019-5-24 09:40
日志的第一个错发出来看看
  • sqlichao sqlichao(提问者) 24-May-2019 08:52:45.153 警告 [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [FineReport] appears to have started a thread named [WebsocketSelector65] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread: sun.nio.ch.WindowsSelectorImpl$SubSelector.poll0(Native Method) sun.nio.ch.WindowsSelectorImpl$SubSelector.poll(WindowsSelectorImpl.java:296) sun.nio.ch.WindowsSelectorImpl$SubSelector.access$400(WindowsSelectorImpl.java:278) sun.nio.ch.WindowsSelectorImpl.doSelect(WindowsSelectorImpl.java:159) sun.nio.ch.SelectorImpl.lockAndDoSelect(SelectorImpl.java:86) sun.nio.ch.SelectorImpl.select(SelectorImpl.java:97) sun.nio.ch.SelectorImpl.select(SelectorImpl.java:101) com.fr.socket.web.server.WebSocketServer.run(Unknown Source) java.lang.Thread.run(Thread.java:748) 24-May-2019 08:52:45.153 警告 [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [FineReport] appears to have started a thread named [Timer-5] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread: java.lang.Object.wait(Native Method) java.util.TimerThread.mainLoop(Timer.java:552) java.util.TimerThread.run(Timer.java:505)
    2019-05-24 09:47
  • 白水先生 白水先生 回复 sqlichao(提问者) 你看是不是进程里面是不是已经启动了一个java,你在进程把java都删掉,再重启试试
    2019-05-24 13:45
allenchouLv3见习互助
发布于2019-5-24 11:42
检查下问题:①查看目标资源路径是否正确
②你部署方式具体可以参考这个文档看下http://help.finereport.com/finereport9.0/doc-view-765.html
③你换换tomcat的版本试试
  • 1445浏览人数
  • 最后回答于:2019-5-24 15:16
