如何将存储过程的数据源拿出来
语句如下,怎样才能让存储过程的数据源在报表里显示出来
USE [UFDATA_001_2021]
GO
/****** Object:  StoredProcedure [dbo].[xSDDYK]    Script Date: 2021-11-29 16:34:54 ******/
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
ALTER  PROCEDURE [dbo].[xSDDYK]
@cInvCode nvarchar(100)=null,
@cfree1 nvarchar(50)=null,
@cInvCCode nvarchar(50)=null,
@cidefine10 nvarchar(50)=null
as
begin
--加索引
--select  sum(dls.fOutQuantity) as 总累计出库数量,dls.cinvcode as 存货编码a,isnull(dls.cfree1,'常规色') as 色号a,dls.cInvName as 存货名称1 into ##tmp1
--from DispatchLists dls
--left join SO_SODetails sds
--on dls .cSoCode=sds.cSOCode
--left join SO_SOMain sm
--on sm.ID=sds.ID
--where dls.cordercode is not null and  sm.dclosedate is null --订单未关闭以及销售订单不为空
--group by dls.cinvcode , dls.cfree1,dls.cInvName --发货单表
----dls.fOutQuantity ,AutoID
----dls.fOutQuantity as 累计出库数量,AutoID
--select   i.cinvname as 存货名称6,i.cInvCode as 存货编码b,case when (cs.cFree1='') then '常规色' else cs.cFree1 end as 色号b,i.cInvStd as 规格型号,sum(cs.iQuantity) as 总现存量 into ##tmp2
--from CurrentStock cs
--left join Inventory i   --/存货档案现存量表--数据正确
--on i.cInvCode=cs.cInvCode
--where left(i.cInvCCode,2)=01 and cs.iQuantity>=0
--group by i.cInvCode ,cs.cFree1,i.cInvStd ,i.cinvname
--select  sds.cInvCode as 存货编码,i.cInvName as 存货名称5 ,isnull(sds.cfree1,'常规色') as 色号c, sum(sds.iQuantity) as 销售订单数量, sum(sds.iFHQuantity )as 累计发货数量,sum(sds.iQuantity) - sum(sds.iFHQuantity ) as 销售订单未开单数量 into ##tmp3
--from SO_SOMain sm
--on sm.id=sds.ID --销售订单主表/子表 数据正确
--on sds.cInvCode =i.cInvCode
--where sm.dclosedate is null
--group by sds.cInvCode,sds.cfree1 ,i.cInvName
--select ie.cInvCode,ie.cidefine10 into ##tmp4
--from Inventory_extradefine ie --存货档案扩展自定义
--select * ,##tmp3.销售订单数量-##tmp1.总累计出库数量 as 销售订单未发货单数量,##tmp2.总现存量-销售订单未开单数量 as 盈亏数,##tmp4.cidefine10 as 是否定制
--from ##tmp3
--left join ##tmp1
--on ##tmp3.存货编码=##tmp1.存货编码a and ##tmp3.色号c=##tmp1.色号a
--left join ##tmp2
--on   ##tmp2.存货编码b=##tmp1.存货编码a and ##tmp2.色号b=##tmp1.色号a
--left join ##tmp4
--on ##tmp3.存货编码= ##tmp4.cInvCode
--where
--(##tmp3.存货编码=@cInvCode or @cInvCode is null)
--and (##tmp3.色号c=@cfree1 or @cfree1 is null)
--drop table ##tmp1,##tmp2,##tmp3,##tmp4
select inc.cInvCCode,cInvCName,ta.cInvCode 存货编码,inv.cInvName 存货名称5,inv.cInvStd 规格型号,ta.cFree1 色号c,ta.iQuantity 销售订单数量,ta.iFHQuantity,
ISNULL(ta.iFHQuantity,0) 累计发货数量,ta.fQuantity 销售订单未开单数量,ISNULL(ct.iQuantity,0) 总现存量,(ISNULL(ct.iQuantity,0)-ta.fQuantity) 盈亏数,cidefine10
from (
select sd.cInvCode,sd.cFree1,sum(sd.iQuantity) iQuantity,sum(iFHQuantity) iFHQuantity,
sum(rd.iQuantity) fOutQuantity,sum(sd.iQuantity-ISNULL(rd.iQuantity,0)) fQuantity2,
sum(CASE WHEN ISNULL(sd.iFHQuantity,0)>sd.iQuantity then 0 else sd.iQuantity-ISNULL(sd.iFHQuantity,0) end) fQuantity
from so_somain sm with(nolock)
inner join so_sodetails sd with(nolock) on sm.ID=sd.ID
left join (select iSOsID,sum(iQuantity) iQuantity from DispatchLists group by iSOsID) rd on sd.iSOsID=rd.iSOsID
--left join (SELECT td.iSOsID,sum(rds.iQuantity) iQuantity
-- FROM rdrecords32 rds
-- inner join rdrecord32 rd on rds.ID=rd.ID
-- left join DispatchLists td on td.iDLsID=rds.iDLsID
-- where ISNULL(rd.cHandler,'')!=''
-- group by td.iSOsID)rd on sd.iSOsID=rd.iSOsID
where ISNULL(sm.cVerifier,'')!='' and ISNULL(sm.cCloser,'')='' and ISNULL(sd.cSCloser,'')=''
group by sd.cInvCode,sd.cFree1--销售订单主表子表
)ta
left join (
select cInvCode,cFree1,
sum(iQuantity+fInQuantity-fOutQuantity+fTransInQuantity-fTransOutQuantity) iQuantity
from currentstock with(nolock)
group by cInvCode,cFree1--现存量表
) ct on ta.cInvCode=ct.cInvCode and ISNULL(ta.cFree1,'')=ISNULL(ct.cFree1,'')
left join inventory inv with(nolock) on ta.cInvCode=inv.cInvCode
left join Inventory_extradefine inf with(nolock) on ta.cInvCode=inf.cInvCode--是否定制
left join InventoryClass inc on left(inv.cInvCCode,2)=inc.cInvCCode--存货大类编码
where 1=1 -- and inc.cInvCCode='01'
and (ta.cInvCode=@cInvCode or @cInvCode is null)
and (ta.cFree1=@cfree1 or @cfree1 is null)
and (inc.cInvCCode=@cInvCCode or @cInvCCode is null)
and (inf.cidefine10=@cidefine10 or @cidefine10 is null)
order by ta.cInvCode
end;
FineReport zhangjinrui 发布于 2021-11-30 11:56
发布于2021-11-30 12:01(编辑于 2021-11-30 16:18)
这两行之间 加 set nocount on
  • zhangjinrui zhangjinrui(提问者) 还是不行
    2021-11-30 16:04
  • Z4u3z1 Z4u3z1 回复 zhangjinrui(提问者) 加了 SET NOCOUNT ON 后直接用。报什么错?如果没数据就把 上图的 SQL 放到数据库管理工具里面执行看看有数据么
    2021-11-30 16:20
  • Z4u3z1 Z4u3z1 回复 zhangjinrui(提问者) ???
    2021-12-01 14:10
  • zhangjinrui zhangjinrui(提问者) 回复 Z4u3z1 还是显示不出来
    2021-12-01 16:28
  • Z4u3z1 Z4u3z1 回复 zhangjinrui(提问者) 私信你了
    2021-12-01 16:31
elaizaLv6初级互助
发布于2021-11-30 15:36
{call SP_REPORTRESULTD --存储过程名
-- 参数
'COM0210',
'${开始日期}',
'${结束日期}',
'${对比开始日期}',
'${对比结束日期}',
-- ?来接收返回的游标数据
  • 333浏览人数
  • 最后回答于:2021-11-30 16:18
