Code:[FrConnection-03], Description:[FR connection error.]. - DataBase[test] get data failed! [select * from id where id in (${id})][limit:5] - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '{id}) limit 0, 5' at line 2 com.fr.dp.exception.FineDPException: Code:[FrConnection-03], Description:[FR connection error.]. - DataBase[test] get data failed! [select * from id where id in (${id})][limit:5] - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '{id}) |
