连接外部mysql数据库报错
navicat上可以正常连接,但使用finereport10.0.17会报错如下错误,
刚刚卸载了重装最新版的也是一样报这个错误,而且我连本地的mysql是连的上的
com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Access denied for user 'query'@'%' to database 'antest'
sun.reflect.NativeConstructorAccessorImpl.newInstance0(NativeConstructorAccessorImpl.java.-2)
sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java.62)
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java.45)
java.lang.reflect.Constructor.newInstance(Constructor.java.423)
com.mysql.jdbc.Util.handleNewInstance(Util.java.403)
com.mysql.jdbc.Util.getInstance(Util.java.386)
com.mysql.jdbc.SQLError.createSQLException(SQLError.java.944)
com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java.3933)
com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java.3869)
com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java.864)
com.mysql.jdbc.MysqlIO.proceedHandshakeWithPluggableAuthentication(MysqlIO.java.1707)
com.mysql.jdbc.MysqlIO.doHandshake(MysqlIO.java.1217)
com.mysql.jdbc.ConnectionImpl.coreConnect(ConnectionImpl.java.2189)
com.mysql.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java.2220)
com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java.2015)
com.mysql.jdbc.JDBC4Connection.
sun.reflect.GeneratedConstructorAccessor132.newInstance(null.-1)
com.mysql.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java.385)
com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java.323)
com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java.1461)
com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java.1525)
com.fr.third.alibaba.druid.pool.DruidDataSource.init(DruidDataSource.java.778)
com.fr.third.alibaba.druid.pool.DruidDataSource.getConnection(DruidDataSource.java.1117)
com.fr.third.alibaba.druid.pool.DruidDataSource.getConnection(DruidDataSource.java.1113)
com.fr.third.alibaba.druid.pool.DruidDataSource.getConnection(DruidDataSource.java.101)
com.fr.stable.pool.DataSourceWrapper.getConnection(null.-1)
com.fr.data.pool.MemoryConnection.create(null.-1)
com.fr.data.auth.Authentication.authenticate(null.-1)
com.fr.data.impl.JDBCDatabaseConnection.createConnection(null.-1)
com.fr.data.impl.JDBCDatabaseConnection.testConnection(null.-1)
com.fr.data.operator.DataOperator$8.call(DataOperator.java.258)
com.fr.data.operator.DataOperator$8.call(DataOperator.java.255)
java.util.concurrent.FutureTask.run(FutureTask.java.266)
java.util.concurrent.Executors$RunnableAdapter.call(Executors.java.511)
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java.1149)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java.624)
java.lang.Thread.run(Thread.java.748)
FineReport 用户YzKXe1260881 发布于 2021-12-22 11:33 (编辑于 2021-12-22 16:26)
悬赏:0 F币 + 添加悬赏
发布于2021-12-22 16:42
那是因为这个账号没有权限,使用root就可以,或者登陆root去给query这个账号添加权限
  • 用户YzKXe1260881 用户YzKXe1260881(提问者) finereport和navicat相比需要额外权限嘛,这个我不太懂,我个人理解是navicat能连接上,那finereport也应该能连接上才对
    2021-12-22 16:45
  • CD20160914 CD20160914 回复 用户YzKXe1260881(提问者) 看这个提示就是这样的。你可以添加一下权限看一下。
    2021-12-22 16:46
发布于2021-12-22 11:37
  • 用户YzKXe1260881 用户YzKXe1260881(提问者) 不是这个原因,版本是10.0.15之后应该是不影响的,而且我刚刚也放到lib下了,还是这个报错
    2021-12-22 12:02
  • 483浏览人数
  • 最后回答于:2021-12-22 16:42
