插件开发gradle报错
Execution failed for task ':dependencies'.
> Could not resolve all dependencies for configuration ':compileClasspath'.
   > Using insecure protocols with repositories, without explicit opt-in, is unsupported. Switch Maven repository 'maven(http://mvn.finedevelop.com/repository/maven-public/)' to redirect to a secure protocol (like HTTPS) or allow insecure protocols. See https://docs.gradle.org/7.3/dsl/org.gradle.api.artifacts.repositories.UrlArtifactRepository.html#org.gradle.api.artifacts.repositories.UrlArtifactRepository:allowInsecureProtocol for more details.
* Try:
> Run with --stacktrace option to get the stack trace.
> Run with --info or --debug option to get more log output.
> Run with --scan to get full insights.
maven服务器镜像配置 - 插件文档 - 开发帮助中心 (fanruan.com)
镜像配置是按照文档里来的
FineReport wenglei 发布于 2022-1-7 14:43 (编辑于 2022-1-7 14:45)
发布于2022-1-7 22:47
-- 二开问题,建议加群咨询;
  • 335浏览人数
  • 最后回答于:2022-1-7 22:47
