我有个sql里有个参数条件,如果为空就查询所有等级三个字段的平均值,怎么写在sql里啊?
FineReport 用户N1887570 发布于 2022-2-8 11:20 (编辑于 2022-2-8 11:20)
发布于2022-2-8 11:23(编辑于 2022-2-8 11:37)
等级为空的时候。查询哪三个字段的平均值?
select
roast_season,
smoke_area,
smoke_type,
${if(len(smoke_level)=0,"AVG(standard_slice_rate) as 出片率,AVG(standard_stem_rate) as 含梗率,
AVG(avg_slice_water) AS 含水率 ","smoke_level,AVG(standard_slice_rate) as 出片率,
AVG(avg_slice_water) AS 含水率")}
from physics_check
group by roast_season,smoke_area,
${if(len(smoke_level)=0,"","smoke_level,")}
smoke_type order by roast_season
  • 用户N1887570 用户N1887570(提问者) select roast_season,smoke_area,smoke_level,smoke_type,AVG(standard_slice_rate) as 出片率,AVG(standard_stem_rate) as 含梗率,AVG(avg_slice_water) AS 含水率 from physics_check group by roast_season,smoke_area,smoke_level,smoke_type order by roast_season
    2022-02-08 11:25
  • 用户N1887570 用户N1887570(提问者) smoke_level 是那个判断字段
    2022-02-08 11:26
  • CD20160914 CD20160914 回复 用户N1887570(提问者) 如果不为空呢?
    2022-02-08 11:27
用户s8245597Lv2见习互助
发布于2022-2-8 11:54
直接  like  '%参数%' 就可以的吧
axingLv6专家互助
发布于2022-7-15 23:56(编辑于 2022-7-15 23:58)
select
from physics_check
where 1=1
${if(len(等级)=0,""," and smoke_level in ('"+等级+"')")}
  • 429浏览人数
  • 最后回答于:2022-7-15 23:58
