这个sql哪里写错了呢,有个判断条件,如果参数‘等级’为空,查询第一段sql,不为空查询第二段
FineReport 用户N1887570 发布于 2022-2-8 11:50 (编辑于 2022-2-8 11:54)
发布于2022-2-8 11:51(编辑于 2022-2-8 11:56)
in('"+等级+"')
if(len(等级)==0,
  • 用户N1887570 用户N1887570(提问者) 他报的是第一行的错
    2022-02-08 11:54
  • Z4u3z1 Z4u3z1 回复 用户N1887570(提问者) 等级 is null 改成 len(等级)==0
    2022-02-08 11:56
发布于2022-2-8 12:27
${if(len(等级)=0,
"select
roast_season,
smoke_area,
smoke_type,
AVG(standard_slice_rate) as 出片率,
AVG(standard_stem_rate) as 含梗率,
AVG(avg_slice_water) AS 含水率
from physics_check
group by roast_season,smoke_area,smoke_type
order by roast_season",
"select
roast_season,
smoke_area,
smoke_type,
from physics_check
where smoke_level in('"+等级 +"') group by roast_season,smoke_area,smoke_type
order by roast_season")}
axingLv6专家互助
发布于2022-7-15 23:59
改成这样:
select
roast_season,smoke_area,smoke_level,smoke_type,
from physics_check
where 1=1
${if(len(等级)=0,""," and smoke_level in ('"+等级+"')")}
group by roast_season,smoke_area,smoke_level,smoke_type
  • 459浏览人数
  • 最后回答于:2022-7-15 23:59
