sql有办法写么数据库类型为sqlserver具体需求如图
krystal033 发布于 2022-3-9 14:01
发布于2022-3-9 14:03(编辑于 2022-3-9 14:42)
用存储过程吧
ALTER procedure Proc_Test
AS
BEGIN
SET NOCOUNT ON;
DECLARE @NAME_ NVARCHAR(100),@RQ_ DATE,@TOTAL_ FLOAT,@CN_ FLOAT,@I FLOAT
/*创建测试表,正式环境不用创建*/
IF OBJECT_ID('TEMPDB..#Table_OLD') is NOT null
DROP TABLE  #Table_OLD
CREATE TABLE #Table_OLD(
[产品名称] [nvarchar](50)NULL,
[交期][DATE] NULL,
[订单数量][float] NULL,
[日产能][float] NULL
/*创建保存结果的临时表*/
IF OBJECT_ID('TEMPDB..#Table_NEW') is NOT null
DROP TABLE  #Table_NEW
CREATE TABLE #Table_NEW(
[日期][DATE] NULL,
[生产数量][float] NULL,
[订单数量][float] NULL,
[日产能][float] NULL
/*创建测试数据*/
INSERT INTO #Table_OLD VALUES('AAA','2022-03-09',10000,2000)
INSERT INTO #Table_OLD VALUES('BBB','2022-03-12',17000,2000)
/*遍历测试数据*/
DECLARE MY_CUR CURSOR
FOR SELECT 产品名称,交期,订单数量,日产能 FROM #Table_OLD
OPEN MY_CUR
FETCH NEXT FROM MY_CUR INTO @NAME_,@RQ_,@TOTAL_,@CN_
WHILE @@FETCH_STATUS = 0
BEGIN
SET @I=@TOTAL_
SET @RQ_=DATEADD(DAY,-1,@RQ_)
/*循环拆分日产能*/
WHILE @I>0 BEGIN
INSERT INTO #Table_NEW VALUES (''+CONVERT(NVARCHAR(100),@NAME_)+'',''+CONVERT(NVARCHAR(100),@RQ_)+'',''+CONVERT(NVARCHAR(100),@CN_)+'',''+CONVERT(NVARCHAR(100),@TOTAL_)+'',''+CONVERT(NVARCHAR(100),@CN_)+'')
SET @I=@I-@CN_
END
END
CLOSE MY_CUR
DEALLOCATE MY_CUR
SELECT * FROM #Table_NEW
END
  • 447浏览人数
  • 最后回答于:2022-3-9 14:42
