应出勤人数/实出勤数量=出勤率,要怎么写数据库
——应出勤人数
SELECT d.depart_name,count(a.emp_id) as 个数
FROM  employee a
left join (select  case ctype when '0' then '固定期限' when '1' then '无固定期限' else '其他' end as 合同类别,* from contact) b on a.emp_id=b.emp_id and b.status=1
left join Degrees c on a.edu_id=c.degree_id
left join Departs d  on left(a.depart_id,7)=d.depart_id
where work_status=1 AND LEFT(a.depart_id,7)='0080101' AND a.depart_id<>'0080101'
group by d.depart_name
——实出勤人数
SELECT c.depart_name,count(DISTINCT a.emp_id) as 个数
FROM dbo.TimeRecords a
INNER JOIN dbo.employeeinfo b ON a.emp_id=b.emp_id
INNER JOIN dbo.Departs c ON LEFT(b.depart_id, 9)=c.depart_id
WHERE CONVERT(VARCHAR(10), a.sign_time, 120)=CONVERT(VARCHAR(10), GETDATE(), 120)
AND LEFT(b.depart_id,7)='0080101' AND b.depart_id<>'0080101'
GROUP BY c.depart_name
FineReport 用户bmXwf6959003 发布于 2022-5-10 11:47
发布于2022-5-10 11:49(编辑于 2022-5-10 11:50)
公式是不是给错了??假设应出勤100,实出勤80 那100/80 岂不是出勤率很高
SELECT B.个数/A.个数*1.0 FROM(
FROM  employee a
) A INNER JOIN (
——实出勤人数
) B ON A.depart_name=B.depart_name
意气Lv7初级互助
发布于2022-5-10 11:50(编辑于 2022-5-10 11:55)
select depart_name,sum(应出勤人数) / sum(实出勤人数) as 出勤率 (
SELECT d.depart_name,count(a.emp_id) as 应出勤人数, 0 实出勤人数
FROM  employee a
union all
SELECT c.depart_name,0 应出勤人数,count(DISTINCT a.emp_id) as 实出勤人数
) a
group by depart_name
  • 322浏览人数
  • 最后回答于:2022-5-10 11:55
