2022/06/07 17:15:09 localhost-startStop-1 ERROR [standard] Job class not found, jobKey: DATA_PREPARE.DATA_PREPARE_FR-FB001. 2022/06/07 17:15:31 localhost-startStop-1 ERROR [standard] Lifecycle error.Error creating bean with name 'defaultServletHandlerMapping' defined in com.fr.third.springframework.web.servlet.config.annotation.DelegatingWebMvcConfiguration: Bean instantiation via factory method failed; nested exception is com.fr.third.springframework.beans.BeanInstantiationException: Failed to instantiate [com.fr.third.springframework.web.servlet.HandlerMapping]: Factory method 'defaultServletHandlerMapping' threw exception; nested exception is java.lang.IllegalStateException: Unable to locate the default servlet for serving static content. Please set the 'defaultServletName' property explicitly. com.fr.third.springframework.beans.factory.BeanCreationException: Error creating bean with name 'defaultServletHandlerMapping' defined in com.fr.third.springframework.web.servlet.config.annotation.DelegatingWebMvcConfiguration: Bean instantiation via factory method failed; nested exception is com.fr.third.springframework.beans.BeanInstantiationException: Failed to instantiate [com.fr.third.springframework.web.servlet.HandlerMapping]: Factory method 'defaultServletHandlerMapping' threw exception; nested exception is java.lang.IllegalStateException: Unable to locate the default servlet for serving static content. Please set the 'defaultServletName' property explicitly. at com.fr.third.springframework.beans.factory.support.ConstructorResolver.instantiateUsingFactoryMethod(ConstructorResolver.java:599) ~[fine-third-11.0.jar:?] at com.fr.third.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateUsingFactoryMethod(AbstractAutowireCapableBeanFactory.java:1176) ~[fine-third-11.0.jar:?] at com.fr.third.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1071) ~[fine-third-11.0.jar:?] at com.fr.third.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:511) ~[fine-third-11.0.jar:?] at com.fr.third.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:481) ~[fine-third-11.0.jar:?] at com.fr.third.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:312) ~[fine-third-11.0.jar:?] at com.fr.third.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230) ~[fine-third-11.0.jar:?] at com.fr.third.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:308) ~[fine-third-11.0.jar:?] at com.fr.third.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197) ~[fine-third-11.0.jar:?] at com.fr.third.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:756) ~[fine-third-11.0.jar:?] at com.fr.third.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:867) ~[fine-third-11.0.jar:?] at com.fr.third.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:542) ~[fine-third-11.0.jar:?] at com.fr.third.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:443) ~[fine-third-11.0.jar:?] at com.fr.third.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:325) ~[fine-third-11.0.jar:?] at com.fr.startup.FineWebApplicationStartup$SpringStarter.executeStart(FineWebApplicationStartup.java) ~[fine-core-11.0.jar:?] at com.fr.stable.lifecycle.AbstractLifecycle.start(AbstractLifecycle.java) [fine-core-11.0.jar:?] at com.fr.startup.FineWebApplicationInitializer$1.contextInitialized(Unknown Source) [fine-decision-11.0.jar:?] at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4761) [catalina.jar:8.5.75] at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5232) [catalina.jar:8.5.75] at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183) [catalina.jar:8.5.75] at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:753) [catalina.jar:8.5.75] at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:727) [catalina.jar:8.5.75] at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:695) [catalina.jar:8.5.75] at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:1177) [catalina.jar:8.5.75] at org.apache.catalina.startup.HostConfig$DeployDirectory.run(HostConfig.java:1925) [catalina.jar:8.5.75] at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_191-1-redhat] at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_191-1-redhat] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_191-1-redhat] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_191-1-redhat] at java.lang.Thread.run(Thread.java:748) [?:1.8.0_191-1-redhat] Caused by: com.fr.third.springframework.beans.BeanInstantiationException: Failed to instantiate [com.fr.third.springframework.web.servlet.HandlerMapping]: Factory method 'defaultServletHandlerMapping' threw exception; nested exception is java.lang.IllegalStateException: Unable to locate the default servlet for serving static content. Please set the 'defaultServletName' property explicitly. at com.fr.third.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:189) ~[fine-third-11.0.jar:?] at com.fr.third.springframework.beans.factory.support.ConstructorResolver.instantiateUsingFactoryMethod(ConstructorResolver.java:588) ~[fine-third-11.0.jar:?] ... 29 more Caused by: java.lang.IllegalStateException: Unable to locate the default servlet for serving static content. Please set the 'defaultServletName' property explicitly. at com.fr.third.springframework.web.servlet.resource.DefaultServletHttpRequestHandler.setServletContext(DefaultServletHttpRequestHandler.java:106) ~[fine-third-11.0.jar:?] at com.fr.third.springframework.web.servlet.config.annotation.DefaultServletHandlerConfigurer.enable(DefaultServletHandlerConfigurer.java:80) ~[fine-third-11.0.jar:?] at com.fr.third.springframework.web.servlet.config.annotation.DefaultServletHandlerConfigurer.enable(DefaultServletHandlerConfigurer.java:68) ~[fine-third-11.0.jar:?] at com.fr.startup.FineWebApplicationConfiguration.configureDefaultServletHandling(FineWebApplicationConfiguration.java) ~[fine-core-11.0.jar:?] at com.fr.third.springframework.web.servlet.config.annotation.WebMvcConfigurerComposite.configureDefaultServletHandling(WebMvcConfigurerComposite.java:73) ~[fine-third-11.0.jar:?] at com.fr.third.springframework.web.servlet.config.annotation.DelegatingWebMvcConfiguration.configureDefaultServletHandling(DelegatingWebMvcConfiguration.java:72) ~[fine-third-11.0.jar:?] at com.fr.third.springframework.web.servlet.config.annotation.WebMvcConfigurationSupport.defaultServletHandlerMapping(WebMvcConfigurationSupport.java:505) ~[fine-third-11.0.jar:?] at com.fr.third.springframework.web.servlet.config.annotation.DelegatingWebMvcConfiguration$$EnhancerBySpringCGLIB$$dae218c5.CGLIB$defaultServletHandlerMapping$40(<generated>) ~[fine-third-11.0.jar:?] at com.fr.third.springframework.web.servlet.config.annotation.DelegatingWebMvcConfiguration$$EnhancerBySpringCGLIB$$dae218c5$$FastClassBySpringCGLIB$$a71264fd.invoke(<generated>) ~[fine-third-11.0.jar:?] at com.fr.third.net.sf.cglib.proxy.MethodProxy.invokeSuper(MethodProxy.java:229) ~[fine-third-11.0.jar:?] at com.fr.third.springframework.context.annotation.ConfigurationClassEnhancer$BeanMethodInterceptor.intercept(ConfigurationClassEnhancer.java:358) ~[fine-third-11.0.jar:?] at com.fr.third.springframework.web.servlet.config.annotation.DelegatingWebMvcConfiguration$$EnhancerBySpringCGLIB$$dae218c5.defaultServletHandlerMapping(<generated>) ~[fine-third-11.0.jar:?] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_191-1-redhat] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_191-1-redhat] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_191-1-redhat] at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_191-1-redhat] at com.fr.third.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:162) ~[fine-third-11.0.jar:?] at com.fr.third.springframework.beans.factory.support.ConstructorResolver.instantiateUsingFactoryMethod(ConstructorResolver.java:588) ~[fine-third-11.0.jar:?] ... 29 more |
