sql求同期值
求同期销售额 sql语句怎么写呀
帆软用户JAQZIqxWYw 发布于 2022-7-12 09:36
发布于2022-7-12 09:37(编辑于 2022-7-12 09:38)
参考
with abc as(select sum((a.单价-a.进价)*a.数量*(1-a.折扣)) as lr,strftime('%Y', 订购日期) as nian,strftime('%m', 订购日期) as yue from 订单明细 a left join 订单 b on a.订单ID = b.订单ID group by nian,yue),e as (select nian as nian1,yue as yue1,lr as lr1 from abc where nian = '${aa}'),f as (select nian as nian2,yue as yue2,lr as lr2 from abc where nian = '${aa -1}')
select (e.nian1||'-'||e.yue1) as 年月,e.lr1 as 销售额,case when lr2 > 0 then (((lr1-lr2)/lr2*100)||'%') else '同期没有数据' end 同比 from e
left join f on e.yue1 = f.yue2
自带内置FRDemo数据库
发布于2022-7-12 09:37
数据库类型 + 同比  度娘 N多方案
shinger@126.comLv2见习互助
发布于2022-7-12 11:24
set nocount on
declare @sdate datetime,@edate datetime --本期开始结束日期
declare @sdate1 datetime,@edate1 datetime  --去年同月开始结束日期
set @sdate='${年月}'+'-01'       --传入年月以2022-06格式
set @edate=dateadd(ms,-3,DATEADD(MONTH,1,@sdate))
set @sdate1=dateadd(year,-1,@sdate)
set @edate1=dateadd(year,-1,@edate)
--本期数据
select 店铺,sum(销售额) as 销售额
  into #本期
  from 销售数据
  where 销售日期 between @sdate and @edate
  group by 店铺
--去年同期数据
  into #同期
  from 销售数据
  where 销售日期 between @sdate1 and @edate1
  group by 店铺
--输出结果
select a.店铺,a.销售额,ISNULL(b.销售额,0) 同期销售额
 from #本期 a
  left join #同期 b on a.店铺=b.店铺
set nocount off
这是MSSQL的代码,同比在报表里面用单元格公式去算。其他数据库大同小异,都可以把本期和同期分别写入2个临时表再关联
  • 403浏览人数
  • 最后回答于:2022-7-12 11:24
