查询报错
总是出java.lang.NullPointerException,求各位大佬看看为啥出错
代码如下
select CS2,code,name,jg  from
(select case when ("'${pz}'" = "'115'" or "'${pz}'" ="'103'" ) then jg_q else jg_c end as jg, CS2,code,name from
  (select  a.code, a.name, a.jg_q, a.jg_c ,b.CS2
  from app_yp.jc_ORC a
  join ALL_D05.ERP_GRAPH_ORC b on a.code= b.zxnjg
  where A.CALDAY = REPLACE('${date}' ,'-','')
  ${IF(pz=="",""," AND A.CS2 IN ("+pz+")")}
  group by b.CS2)
group by CS2)
FineReport 用户x076327 发布于 2022-7-19 14:36
共5回答
发布于2022-11-2 20:15
字段一般不用单号而且你还套了双引号。同时你的替换日期的函数没用对
SELECT CS2,code,NAME,jg  FROM
(SELECT CASE WHEN (${pz} = '115' OR ${pz} ='103' ) THEN jg_q ELSE jg_c END AS jg, CS2,code,NAME FROM
  (SELECT  a.code, a.NAME, a.jg_q, a.jg_c ,b.CS2
  FROM app_yp.jc_ORC a
  JOIN ALL_D05.ERP_GRAPH_ORC b ON a.code= b.zxnjg
  WHERE A.CALDAY = ${Replace(date ,'-','')}
  GROUP BY b.CS2)a
GROUP BY CS2)b
好好生活好好学习Lv7资深互助
发布于2022-7-19 14:37(编辑于 2022-7-19 14:37)
where A.CALDAY = '${REPLACE(date,"-","")}'
lxy2Lv6中级互助
发布于2022-7-19 14:38
(SELECT CASE WHEN ('${pz}' = '115' OR '${pz}' ='103' ) THEN jg_q ELSE jg_c END AS jg, CS2,code,NAME FROM
  WHERE A.CALDAY = Replace('${date}' ,'-','')
  GROUP BY b.CS2)a
GROUP BY CS2)b
发布于2022-7-19 14:41
这两个是115还是'115'   ??
yzm339714Lv6中级互助
发布于2022-7-19 14:44
最里面的一层select 没有加反括号把
  ${IF(pz=="",""," AND A.CS2 IN ("+pz+")")})
  group by b.CS2)
group by CS2)
  • 429浏览人数
  • 最后回答于:2022-11-2 20:15
