com.fr.plugin.mobile.web.server.config.Html5Config has the same tableName with com.fr.plugin.mobile.web.server.config.Html5Config
H5 设置-https://help.fanruan.com/finereport/doc-view-3475.html
H5解析异常了,将「 HTML5移动端展现」插件禁用(卸载)后,重新启用(安装) 即可!
tablename一样拉?
