BI数据准备sql数据集:怎么获取系统的用户信息,sql怎么写
FineBI 赵超凡 发布于 2022-8-3 14:50
发布于2022-8-3 14:53
看下面语句,都有的,BI和fr一样的
SELECT * FROM (
select
u.ID 用户ID,
u.USERNAME ,
u.REALNAME 姓名,
rc.id 角色ID,
rc.NAME 角色 ,
rd.id 部门ID,
d.NAME 部门
from FINE_USER u
left join FINE_USER_ROLE_MIDDLE rm on u.id=rm.userId
left join FINE_CUSTOM_ROLE rc on rm.ROLETYPE=2 and rm.ROLEID=rc.id
left join FINE_DEP_ROLE rd on rm.ROLETYPE=1 and rm.ROLEID=rd.id
left join FINE_DEPARTMENT d on d.id=rd.DEPARTMENTID
left join FINE_POST p on p.id=rd.POSTID
 where 1=1 ${if(len(fine_username) == 0,"","and u.USERNAME ='"+fine_username+"' ") }
) A
JOIN (
select
F.roleid,
case when f.AUTHORITYTYPE='1' then '查看权限'
when f.AUTHORITYTYPE='2' then '授权权限'
when f.AUTHORITYTYPE='3' then '编辑权限'
when f.AUTHORITYTYPE='4' then '数据连接管理权限'
when f.AUTHORITYTYPE='101' then 'FineReport 模板认证权限'
when f.AUTHORITYTYPE='102' then 'FineReport 模板查看权限'
when f.AUTHORITYTYPE='103' then 'FineReport 模板填报权限'
when f.AUTHORITYTYPE='201' then '业务包使用权限'
when f.AUTHORITYTYPE='202' then '业务包管理权限'
when f.AUTHORITYTYPE='203' then 'BI报表导出权限'
when f.AUTHORITYTYPE='204' then 'BI仪表板分享权限'
when f.AUTHORITYTYPE='205' then 'BI模板认证权限'
when f.AUTHORITYTYPE='206' then 'BI模板查看权限'
when f.AUTHORITYTYPE='207' then 'BI模板导出权限'
when f.AUTHORITYTYPE='208' then 'BI仪表板分享角色控制权限'
when f.AUTHORITYTYPE='209' then 'BI仪表板分享功能权限'
when f.AUTHORITYTYPE='210' then 'BI仪表板公共链接功能权限' end AUTHORITYTYPE,
case when f.ROLETYPE='1' then '部门'
when f.ROLETYPE='2' then '角色'
when f.ROLETYPE='3' then '用户'
when f.ROLETYPE='4' then '职务' end 类型,
a.ID,
a.DISPLAYNAME ,
a.SORTINDEX,
a.PARENTID PARENTID0,
b.PARENTID PARENTID1,
c.PARENTID PARENTID2,
d.PARENTID PARENTID3,
e.PARENTID PARENTID4,
case when a.EXPANDTYPE='1' then '平台管理系统节点'
when a.EXPANDTYPE='2' then '首页'
when a.EXPANDTYPE='3' then '目录'
when a.EXPANDTYPE='5' then '链接'
when a.EXPANDTYPE='6' then '文件'
when a.EXPANDTYPE='101' then '上报流程'
when a.EXPANDTYPE='102' then ' FineReport报表'
when a.EXPANDTYPE='201' then ' BI报表'
 end 权限目录类型,
case when a.DEVICETYPE='0' then '未勾选 '
when a.DEVICETYPE='1' then 'PC '
when a.DEVICETYPE='2' then '平板 '
when a.DEVICETYPE='3' then 'PC、平板 '
when a.DEVICETYPE='4' then '手机 '
when a.DEVICETYPE='5' then 'PC、手机 '
when a.DEVICETYPE='6' then '平板、手机 '
when a.DEVICETYPE='7' then 'PC 、平板、手机 ' end  适用平台, a.SORTINDEX 排序顺序
from FINE_AUTHORITY_OBJECT a
left join FINE_AUTHORITY_OBJECT b on a.PARENTID=b.id
left join FINE_AUTHORITY_OBJECT c on b.PARENTID=c.id
left join FINE_AUTHORITY_OBJECT d on c.PARENTID=d.id
left join FINE_AUTHORITY_OBJECT e on d.PARENTID=e.id
 join FINE_AUTHORITY f on f.AUTHORITY=2 and (a.id=f.AUTHORITYENTITYID or a.PARENTID=f.AUTHORITYENTITYID or b.PARENTID=f.AUTHORITYENTITYID or c.PARENTID=f.AUTHORITYENTITYID
or d.PARENTID=f.AUTHORITYENTITYID or e.PARENTID=f.AUTHORITYENTITYID)
where
not exists (select 1 from  FINE_AUTHORITY f1 where f1.AUTHORITY=1 and (a.id=f1.AUTHORITYENTITYID or a.PARENTID=f1.AUTHORITYENTITYID or b.PARENTID=f1.AUTHORITYENTITYID or c.PARENTID=f1.AUTHORITYENTITYID or d.PARENTID=f1.AUTHORITYENTITYID or e.PARENTID=f1.AUTHORITYENTITYID) and f.roleid=f1.roleid and f.AUTHORITYTYPE=f1.AUTHORITYTYPE)
-- and  f.roleid='old-platform-custom-1'
order by a.PARENTID,a.SORTINDEX) B ON A.用户ID=B.roleid OR A.角色ID=B.roleid   OR A.部门ID=B.roleid
  • 265浏览人数
  • 最后回答于:2022-8-3 14:53
