求助-Ubuntu18.04LTS系统安装Finebi报错
报错信息如下:
java.lang.NoClassDefFoundError: Could not initialize class java.awt.Toolkit
at javax.swing.ImageIcon.<init>(ImageIcon.java:198)
at javax.swing.ImageIcon.<init>(ImageIcon.java:217)
at com.install4j.runtime.installer.frontend.GUIHelper.loadIcon(GUIHelper.java:193)
at com.install4j.runtime.installer.frontend.GUIHelper.<clinit>(GUIHelper.java:52)
at com.install4j.runtime.installer.frontend.headless.AbstractHeadlessScreenExecutor.init(AbstractHeadlessScreenExecutor.java:73)
at com.install4j.runtime.installer.frontend.headless.ConsoleScreenExecutor.<init>(ConsoleScreenExecutor.java:24)
at com.install4j.runtime.installer.frontend.headless.InstallerConsoleScreenExecutor.<init>(InstallerConsoleScreenExecutor.java:6)
at com.install4j.runtime.installer.Installer.getScreenExecutor(Installer.java:87)
at com.install4j.runtime.installer.Installer.runInProcess(Installer.java:56)
at com.install4j.runtime.installer.Installer.main(Installer.java:45)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at com.exe4j.runtime.LauncherEngine.launch(LauncherEngine.java:85)
at com.install4j.runtime.launcher.UnixLauncher.start(UnixLauncher.java:66)
at install4j.Installer255650799.main(Unknown Source)
System properties:
java.runtime.name=OpenJDK Runtime Environment
exe4j.moduleName=//linux_unix_FineBI5_1-CN.sh
sun.boot.library.path=/linux_unix_FineBI5_1-CN.sh.5132.dir/jre/lib/amd64
java.vm.version=25.332-b09
java.vm.vendor=Temurin
java.vendor.url=https://adoptium.net/
path.separator=:
java.vm.name=OpenJDK 64-Bit Server VM
file.encoding.pkg=sun.io
user.country=US
sun.java.launcher=SUN_STANDARD
sun.os.patch.level=unknown
install4j.exeDir=//
java.vm.specification.name=Java Virtual Machine Specification
user.dir=/linux_unix_FineBI5_1-CN.sh.5132.dir
java.runtime.version=1.8.0_332-b09
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.endorsed.dirs=/linux_unix_FineBI5_1-CN.sh.5132.dir/jre/lib/endorsed
os.arch=amd64
java.io.tmpdir=/tmp
line.separator=
java.vm.specification.vendor=Oracle Corporation
os.name=Linux
exe4j.totalDataLength=1061630267
sun.java2d.noddraw=true
sun.jnu.encoding=UTF-8
install4j.defaultLanguage=zh_CN
java.library.path=//linux_unix_FineBI5_1-CN.sh.5132.dir/user::/usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
install4j.launcherId=72817
java.specification.name=Java Platform API Specification
java.class.version=52.0
sun.management.compiler=HotSpot 64-Bit Tiered Compilers
os.version=4.15.0-29-generic
install4j.swt=false
install4j.cwd=/
user.home=/root
user.timezone=Asia/Shanghai
java.awt.printerjob=sun.print.PSPrinterJob
install4j.jvmDir=/linux_unix_FineBI5_1-CN.sh.5132.dir/jre
file.encoding=UTF-8
java.specification.version=1.8
java.class.path=i4jruntime.jar:launcher0.jar
user.name=root
java.vm.specification.version=1.8
sun.java.command=install4j.Installer255650799
java.home=/linux_unix_FineBI5_1-CN.sh.5132.dir/jre
sun.arch.data.model=64
user.language=en
java.specification.vendor=Oracle Corporation
awt.toolkit=sun.awt.X11.XToolkit
java.vm.info=mixed mode
java.version=1.8.0_332
java.ext.dirs=//linux_unix_FineBI5_1-CN.sh.5132.dir/jre/lib/ext://linux_unix_FineBI5_1-CN.sh.5132.dir/jre/jre/lib/ext
sun.boot.class.path=/linux_unix_FineBI5_1-CN.sh.5132.dir/jre/lib/resources.jar:/linux_unix_FineBI5_1-CN.sh.5132.dir/jre/lib/rt.jar:/linux_unix_FineBI5_1-CN.sh.5132.dir/jre/lib/sunrsasign.jar:/linux_unix_FineBI5_1-CN.sh.5132.dir/jre/lib/jsse.jar:/linux_unix_FineBI5_1-CN.sh.5132.dir/jre/lib/jce.jar:/linux_unix_FineBI5_1-CN.sh.5132.dir/jre/lib/charsets.jar:/linux_unix_FineBI5_1-CN.sh.5132.dir/jre/lib/jfr.jar:/linux_unix_FineBI5_1-CN.sh.5132.dir/jre/classes
java.awt.headless=true
install4j.appDir=//
java.vendor=Temurin
file.separator=/
java.vendor.url.bug=https://github.com/adoptium/adoptium-support/issues
sun.font.fontmanager=sun.awt.X11FontManager
sun.io.unicode.encoding=UnicodeLittle
sun.cpu.endian=little
sun.cpu.isalist=
麻烦各位大神帮忙分析一下,谢谢!
FineBI 用户K4017049 发布于 2022-8-15 11:26
用户K4017049Lv1见习互助
发布于2022-8-15 13:41
系统组件版本问题,更新后解决
runerLv7资深互助
发布于2022-8-15 11:27(编辑于 2022-8-15 11:27)
  • 428浏览人数
  • 最后回答于:2022-8-15 13:41
