这个第一行有什么问题啊
delimiter //
CREATE PROCEDURE test_if_pro(in sal DOUBLE)
BEGIN
  if sal < 3000
    then delete from employees where salary = sal;
elseif sal <=5000
     then UPDATE employees set salary=salary + 1000 where salary = sal;
else
  update employees set salary = salary + 500 where salary = sal;
END if;
END //
delimiter ;
delimiter ;
1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'delimiter' at line 1
SQL yzm551263 发布于 2022-8-19 13:45
悬赏:0 F币 + 添加悬赏
StudyYLLv6初级互助
发布于2022-8-19 14:06(编辑于 2022-8-19 14:16)
https://blog.csdn.net/xkdlzy/article/details/123918971
直接
BEGIN
  if sal < 3000
elseif sal <=5000
else
END if;
END
如果是在Navicat或其他工具执行的话不需要
delimiter //
delimiter ;
runerLv7资深互助
发布于2022-8-19 14:09
数据集不能执行 增删改
  • 444浏览人数
  • 最后回答于:2022-8-19 14:16
